07-30-2019, 11:43 PM | #1 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
Catback install help
How on Earth do I remove this clamp?? It's on the driver side between the primary and secondary cats on my 18 SS 1LE with NPP. I have the AWE Catback and performance link pipes to put on but I can't get this one clamp off. The whole thing feels loose and I can move the bottom of it. Only part that is snug is up top by the stud. I'm lost and tired and sure I'm missing something silly. This is also being done on a garage floor so any tips will save me alot of swearing
07-30-2019, 11:47 PM | #2 |
Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
That clamp has a small tack weld at the top preventing it from being removed. You’ll have to cut that weld to remove it.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
07-31-2019, 12:02 AM | #3 |
Isn't that weld part connected to the outside of the clamp and the inlet pipe? That shouldn't effect the outlet pipe from being pulled through right? Does anyone have any pictures?
07-31-2019, 06:05 AM | #4 |
I thought your were asking how to remove the clamp. The clamp is welded to the primary cat side of the exhaust. If you don’t want to remove the clamp but just remove the pipe, then just give the pipe a good solid tug or two. I had to take a rubber mallet and bang on the secondary cat to get the pipe to separate from the coupler.
Fair warning, if you leave the clamp on and try to re-use it, you may get a leak. I did. I had to remove the clamp and use an accuseal clamp in its place.
07-31-2019, 06:06 AM | #5 |
Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
The pipe slides off, but the clamp is spot welded and also has a "raised lip" around it.
To remove the clamp the pipe needs to come off first |
07-31-2019, 06:21 AM | #6 |
The AWE system comes with a new clamp that goes there. So I have to be able to get the pipe off, then cut the clamp? Or cut the clamp then remove the pipe?
It's already fairly loose and the pipe won't budge |
07-31-2019, 08:17 AM | #7 |
Loosen the clamp, pull the pipe off then cut the clamp off.
07-31-2019, 08:38 AM | #8 |
07-31-2019, 09:00 AM | #9 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Cut it before removing the pipe, that's what I did
07-31-2019, 09:23 AM | #10 |
07-31-2019, 09:30 AM | #11 | |
I took a hack saw blade and cut it. That gave me enough room to just use that to cut it by hand with the shortened blade. If you can get a Dremel up there, great. Space is limited so the hack saw blade worked like a charm for me.
07-31-2019, 09:42 AM | #12 |
Just to confirm, you cut on the bracket that is welded to to primary cat pipe and the clamp itself?
07-31-2019, 10:01 AM | #13 |
Yeah, i just used some tin snips
