07-27-2019, 12:45 PM | #1 |
Drives: 2017 Camaro RS Fiftieth Anniversary Join Date: Oct 2017
Front Fuse Box assistance needed
I am installing a wireless front bumper view camera on my Fifty and want to use one of the open fuses in the front engine bay fuse box to power it. I'd like to find one that does not retain power after engine shutdown, don't want the camera to cause a parasitic drain, no matter how small. Nothing in the owner's manual gives me a clue, can anybody give me any direction? Just need a low amp fuse that does not retain power. The camera will turn on automatically when with a certain distance of an object so I don't want it to work once the car is parked and shut down.
07-27-2019, 12:51 PM | #2 |
Drives: '18 Camaro SS Redline, '20 Bolt EV Join Date: Jul 2018
Can't you check the terminals with a multi-meter?
07-27-2019, 01:07 PM | #3 |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
There's a few I would check that should be ignition source rather than RAP sources, especially since it looks like you don't have an SS.
Like: F43 F45 F49 F51
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51 Ordered 2024 Radiant Red 2SS 1LE Ordered: 6/15/23 Accepted: 7/5/23 3000 - 7/5 ---> 3100 - 7/19 3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7 4300 - 8/14 --->4B00 - 9/5 DELIVERED 9/20!! |
07-30-2019, 11:26 PM | #4 |
all newer GM fuse boxes have fuses in them whether the car has the options or not. if its empty its probably doesnt have power. get a https://www.amazon.com/Vehicle-Micro...gateway&sr=8-8
07-30-2019, 11:56 PM | #5 |
Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
I believe they were using #51 for the front parking sensors, should work for the camera, if you haven't already pulled it for the exhaust.
What kit are you going with?
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
07-31-2019, 06:40 AM | #6 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Even if exhaust is pulled you can stick in an add-a-circuit Fuse TAP if it's not too big for that position and not populate that fuse.
07-31-2019, 12:50 PM | #7 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
The fuse tap listed will work. You need to be sure to put the pin on the left in the hot side of the fuse slot.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
