Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 06-24-2016, 09:14 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro SS Borla ATAK Axle-back 11923 Non NPP Single Tip
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gases, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds.
Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used).
•Rear Section ATAK Dual Exhaust System
•2.75" into muffer dual 2.5" out
•This system is for vehicles that come from the factory with single tips are not equipped with NPP (dual mode exhaust).
Item # 11923
Website Link : http://www.rpidesigns.com/shop/item....pp-single-tip/
RPIDon is offline   Reply With Quote
Old 10-21-2018, 09:11 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Use coupon code LANA5 to save 5% off your order!
