Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 04-06-2016, 09:43 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro SS Stainless Works Exh. Catback w/AFM Valves/Valved Quad Tips
2016 Camaro SS Stainless Works Exhaust Catback w/AFM Valves and Valved Quad Tips
Factory Connect option fits to the factory break-point. The system starts with flanged & slip-fit connections to easily bolt to your existing factory connection point. From there the exhaust travels into our crossover x-pipe with resonators. Includes functional AFM Valves in the tailpipes.2016 Camaro SS exhaust system featuring 3" mandrel bent tubing into S-Tube muffler with 5" diameter slash cut tips.
Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers.
Features:
‣ 3" diameter system
‣ 3" port-matched flanges
‣ Support For Dual-Mode Performance Upgrade Including Functioning Valve
‣ 304 stainless steel construction
‣ TIG welded for strength
‣ Mandrel bent (no buckling) for optimal flow
‣ Design and Made in Chagrin Falls, Ohio, USA
Performance and Sound Proudly Made in the USA
Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship.
Make It Your Own With Custom Options
Choose Your Connection: Stainless Works Camaro systems come in two configurations: Factory Connect and Performance Connect.
Factory Connect allows our headers or exhaust to easily bolt to the factory exhaust or manifolds respectively. They connect at the factory location which is necked-down to accommodate fitment.
Performance Connect is designed to take advantage of performance gains not possible with the standard factory connection point. Both SW headers and SW exhaust are used in this configuration. We've developed a system which maintains a full 3" diameter and X-pipe which creates the ultimate horsepower experience.
Item # CA16FVCB
Website Link : http://www.rpidesigns.com/shop/item....and-dual-tips/
RPIDon is offline   Reply With Quote
Old 07-31-2020, 08:32 AM   #2
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2016-2018 Camaro SS Stainless Works Exhaust Catback w/AFM Valves and Valved Quad Tips
Item # CA16FVCB
RPI Designs is offline   Reply With Quote
