10-03-2022, 07:33 AM | #29 |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
My 2017 still has the original battery. I'm only at 22000 miles and its a real garage queen with a battery tender on it from November through March. I had a 2009 G8 that kept the battery for over 7 years. I do believe keeping them in the rear of the vehicle away from engine heat makes a huge difference. Also being in a more temperate climate here in the south helps quite a bit too. If I was still in Canada this battery would have been swapped by now.
09-13-2023, 11:05 PM | #30 | |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
Hit 60,000 miles today. Had a hot start issue after running into the grocery store for ~10 minutes and needed a jump start. Looks like I'll be replacing my original battery.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
09-14-2023, 03:55 AM | #31 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I kept my 2010 2SS on a battery tender when it wasn't being driven. I replaced the 2010 battery in 2021.
09-14-2023, 05:55 AM | #32 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I had to replace my 2019 3 months ago. Kicking myself for not checking amazon, auto zone charged me $289 with core charges smh.
09-14-2023, 06:49 AM | #33 |
09-15-2023, 08:22 AM | #34 |
Drives: Chevrolet Camaro Join Date: Sep 2023
I throw a battery tender on my batteries for a day or 2 almost every week. Doing this caused my Harley Davidson Fat Boy Battery to last 10 + years. That is a long time for a Harley Battery to last. Hopefully it will help out with the Camaro.
09-15-2023, 09:51 AM | #35 |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
Mine is starting to get week in the “winter” but otherwise hanging on, lmao.
I’ll replace it if Ido not get a 242SS.
2017 2LT RS 3.6L A8.
09-15-2023, 03:34 PM | #36 |
Drives: '23 1SS 1LE | '18 1LS V6 [sold] Join Date: Jul 2020
My 2018 1LS V6 was on the original battery for as long as until March 2023, when I sold it.
09-15-2023, 06:34 PM | #37 |
Drives: Camaro Join Date: Jun 2023
2017, still going.
09-15-2023, 10:32 PM | #38 |
Drives: 2SS 1LE Join Date: Oct 2011
Mine is 2018. Keep it on a trickle charger in the winter.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
09-15-2023, 10:56 PM | #39 |
My car is a 2018, and the original 700 CCA battery tested at only 420 CCA earlier this year, so I decided to replace it after 5.5 years. Never had a problem starting the car, but I did notice the cranking become a bit more labored over time. I also kept it on a trickle charger when not using it for longer periods, so I guess about 6 years is how much these can be expected to last.
09-15-2023, 11:34 PM | #40 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
2017, no trickle charger, driven daily, still strong, now seven years old since built. Trunk mounted batteries have a huge advantage due to heat avoidance. My 2006 Dodge Charger battery, trunk mounted, lasted 12 years.
09-16-2023, 12:42 AM | #41 |
Drives: Camaro SS Join Date: Aug 2023
I replaced mine at about 64k miles and 6 years of use. Battery was still good but decided to replace it because of age.
09-16-2023, 01:00 AM | #42 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
Consumer Reports - Car Battery Buying Guide
Proactive replacement after 5 years in my 2017 ZL1. Bought Interstate AGM at Costco, installed by local independent shop with oil change. |
