12-07-2019, 12:54 PM | #1 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Car would not respond to key fob
Yesterday went grocery shopping with my 2017 SS and after I unlocked the doors and opened the trunk to put the groceries in I opened the drivers door and with the door open I hit the starter button and got "No Fob Detected". I shut the door and placed the fob into the rear facing cup holder still no fob detected. I then got out of the car shut the door and hit the lock button and nothing. Tried all buttons but no response. So I got back in the car shut the door put the fob back into the cup holder and it fired up. Decided to to go straight home and checked the battery in the fob which I replaced last year and it was still good. Have not had a repeat as of yet but decided to use the spare fob from now on. Anyone else have this issue? Is it the fob or just another GM quirk? I know our Lincoln MKX did it once but the issue did not recur. I am now worried about taking the car far from home.
12-07-2019, 01:33 PM | #2 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
Strange. Were you close to a fast-food drive-through? My G8 does that whenever parked close to a certain In and Out Burger. Thinking it's getting interference from their two-way.
12-07-2019, 04:03 PM | #3 | |
Drives: Camaro SS 1LE Join Date: Aug 2018
12-07-2019, 05:19 PM | #4 |
Drives: 2017 Mosaic Black 2SS Join Date: Jul 2013
Have had the same problem several times as well. It cures itself after waiting a few minutes but not sure what the cause is.
12-07-2019, 06:00 PM | #5 |
Drives: camaro 50generation Join Date: Apr 2019
fob
I had the same problem with my 2017 50th Anniversary ss.There is a bulletin on that problem. There is a module in the trunk that is bad.there is a thread here in the forums.
12-07-2019, 07:53 PM | #6 |
12-07-2019, 07:55 PM | #7 |
12-09-2019, 12:08 AM | #8 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
The receiver for the fob is bad. New one PN# 13523281
12-09-2019, 10:30 AM | #9 |
Rick's6inNJ
I just had the control module in the center console replaced based on TSB 16-NA-396. In the 2 years I have owned my Camaro it has happened 3 times where I took a short trip (store, post office, etc.) and when going back to the car it did not respond at all to the key fob, the door sensors didn't work, etc. Basically dead. I waited 10 minutes and it would all start to work again.
Hopefully the new module will fix the issue. |
12-09-2019, 10:43 AM | #10 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
I have this happen in a 2018 Suburban I own. I think I will take it to the dealer to sort out.
12-09-2019, 12:42 PM | #11 |
The part number I gave is for a 2019 model.
2016-2019 there has been 3 revisions of the part. |
