Old 10-12-2022, 11:37 AM   #29
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
i use a coke bottle cut the bottom off. i know it's clean then. then just throw it away once the oil is changed
Camaro fanboy is offline   Reply With Quote
Old 10-12-2022, 12:01 PM   #30
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
The Mobil 1 oil containers are actually perfect for this, just cut off the bottom at an angle. The back end is held up by the strut tower and you can leave a bottle inside the cut-off bottle to finish draining.
Old 10-24-2022, 10:54 PM   #31
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
prestone funnel... does the job, but have to admit that 10 separate quarts gets old, fast.
https://www.acehardware.com/departme...E&gclsrc=aw.ds
fj5gtx is offline   Reply With Quote
Old 10-25-2022, 12:30 PM   #32
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
I used the same last night since I had a few laying around, it was easy. Not a big deal, IMO. Just hold the funnel and pour in the oil. Nothing glamorous.
Watching a stream of oil shoot out of the drain hole and almost reach the passenger tire was a sight, for sure! Glad I had a large catch pan!
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Old 10-10-2023, 03:41 PM   #33
Shock and Steel
Shock and Steel's Avatar
Drives: 2023 Camaro Convertible 2LT
I finally found a benefit of the I4 Turbo engine - the oil filler cap is parallel to the ground. So the 1/2 turn funnel will sit up perfectly vertical. Yay! I know most V8 owners would say "I'd rather have the sound, power, hood, and everything else that comes with the V8," but I have to have something positive to grasp onto...
Shock and Steel is offline   Reply With Quote
Old 10-10-2023, 04:40 PM   #34
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Plus when gasoline is $12 a gallon You will have something to grasp onto!
CalgaryZL1 is online now   Reply With Quote
Old 10-11-2023, 07:28 PM   #35
Shock and Steel
Agreed. I’m over 2,800 miles now, average MPG is 26! It’s plenty of power for me.
Old 10-21-2023, 04:49 PM   #36
CalgaryZL1
CalgaryZL1's Avatar
I love this 9circle set up with the 45° adaptor.
Old 10-21-2023, 07:02 PM   #37
Allez
Allez's Avatar
Nice - where'd you get the 45 degree adapter? I have the same funnel (I think) but without an adapter the angle doesn't work.
Allez is offline   Reply With Quote
Old 10-22-2023, 04:46 AM   #38
CalgaryZL1
CalgaryZL1's Avatar
GM Part Number: 12609623
Old 10-22-2023, 09:41 AM   #39
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
I've been thinking of getting this setup too. But isn't there an adapter that puts the funnel straight up instead of off at an angle?
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 10-31-2023, 10:34 AM   #40
beaurrr
Drives: 2014 C7 z51 m7
I like this setup because the funnel can sit on top rather than at an angle.
beaurrr is offline   Reply With Quote
