Old 02-17-2016, 03:41 PM   #15
buck_dawg_gold
buck_dawg_gold's Avatar
I put mid grade in my 2010 2LT/RS.
2016 Nightfall Gray 2SS A8 NPP Low Gloss Black Wheels
buck_dawg_gold is offline   Reply With Quote
Old 02-17-2016, 04:27 PM   #16
freddyD
Drives: 2020 rally green rs
gac is cheap now! Well here it is,y not bump up a grade or two?
freddyD is offline   Reply With Quote
Old 02-17-2016, 04:35 PM   #17
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
Originally Posted by SSport16 View Post
My LFX 3.6 L in my SRX gets 87 every fill up, no need for any higher octane. Runs awesome!
Yeah, that's the same motor in my Colorado.....NOT the new Camaro 3.6. And probably no where near the potential. Do a tune and you'll be happier! Mine is great with the Diablo 93 tune...
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 12-03-2016, 01:41 PM   #18
tsanchez18
Software Architect
tsanchez18's Avatar
Drives: 2017 Camaro 2.0L Turbo
so what does a 1lt with turbo 4 gas needs?
tsanchez18 is offline   Reply With Quote
Old 12-03-2016, 02:06 PM   #19
Zack46
Zack46's Avatar
Originally Posted by Zultain7 View Post
You should usually stick with what is being said by the manufacturer when it comes to fuel.
+1
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 12-03-2016, 02:21 PM   #20
monkeychops
monkeychops's Avatar
Drives: 2016 V6 6 speed
87 works just fine with 6 banger
monkeychops is offline   Reply With Quote
Old 12-03-2016, 02:40 PM   #21
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Requires Premium, that's 91 for my location. The user manual states not to use anything else.
edgehead2000 is offline   Reply With Quote
Old 12-03-2016, 03:19 PM   #22
glovo
Drives: Camaro 2016 1LT RS
On 93 u can feel the gears bang harder when they change so definitely bit more power and throttle response. On premium I get better milage
glovo is offline   Reply With Quote
Old 03-14-2019, 10:04 PM   #23
wintertopdown
Drives: 22 Convertible V8 LT1
I have only used premium and can reach 25-28 mpg. Computer read 35mpg while in cruise control in 6th gear.
wintertopdown is offline   Reply With Quote
Old 03-18-2019, 05:10 PM   #24
redcoats1976
i use 89 in my V6,could probably get by with 87 but thats lawnmower gas and i cant bring myself to do it.
redcoats1976 is offline   Reply With Quote
Old 03-18-2019, 05:16 PM   #25
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
All you're doing is pissing money away. As far as the ECM is concerned, there is absolutely no difference between 87 and 89. It will run exactly the same and get the same fuel mileage because 89 will not be enough to push it off the 87 fuel map.
You will need to step up to 93 for it move to a higher octane fuel map to get better performance and fuel mileage.
And it doesn't 'get by' with 87. 87 is what it was initially designed for and does quite well with it. All of my highest fuel mileage trips in my 1LT V6 was done on 87 and some of those exceeded 40 MPG.
Need4Camaro is offline   Reply With Quote
Old 03-18-2019, 05:45 PM   #26
Captain J
Captain J's Avatar
Drives: 2017 V6 RS Covertible
Maybe my 1LT V6 RS isn't broken in quite yet but I've never gotten an average MPG of 40. I run 87 fuel and have never gotten better than 34 MPG.
Captain J is offline   Reply With Quote
Old 03-18-2019, 06:03 PM   #27
Need4Camaro
I also never really averaged 40 MPG on daily trips, those pulls were all on long road trips.
On my daily commute I got between 27 and 31 80% steeet and 20% highway, and when I was all highway around Atlanta I got between 35 - 37.
The EPA sticker numbers on the V6 cars are underrated and many people believe that SS's get about the same fuel mileage as the V6 models. They are wrong. on average and similar commutes / driving style my V6 got about 8 - 9 MPG more than my current SS.
Old 03-18-2019, 09:48 PM   #28
karmatourer
STD free
karmatourer's Avatar
Drives: 2018 Bright Yellow LGX M6 RS NPP
FIANLLY! The correct answer and it only took 25 posts and 2 years!!!!! I use 87 in mine and on a rare occasion,throw in a little 9X just for grins.
karmatourer is offline   Reply With Quote
