05-20-2019, 11:34 AM | #43 | |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
As most here will say when the valves are open it allows the exhaust to take the least path of resistance and bypass the chambered area of the muffler.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
05-20-2019, 11:46 AM | #44 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
DUAL tips are not standard on an SS, at least not on a '16. A friend of mine has a '16 2SS, single tip, no NPP option.
'17 2SS ■ HBM '23 3LT RS ■ Rapid Blue '11 2LT RS ■ Red Jewel |
05-20-2019, 12:36 PM | #45 | |
Drives: 2019 ZL1 1LE Join Date: Mar 2014
Exhaust gasses still enter the first chamber of the muffler. Therefore not a bypass. Put a flow meter upto the inner tops with the npp vavles open. A very small but mesureble amount of airflow comes out. Npp is a way to get around the law for exhust bypass's. That's why it's designed how it is. If not they would of saved a ton of money and just dumped it before the muffler. |
05-20-2019, 01:33 PM | #46 | |
You can ask for a retraction on misusing the word describing the NPP. You will find that word you can't deal with in fifth paragraph http://gmauthority.com/blog/2015/04/...-mode-exhaust/ Adding to the 2016 Camaro’s adjustable personality is the dual-mode exhaust. The system uses electronically controlled flaps to bypass the mufflers and provide a more spirited, aggressive sounding exhaust note under heavy acceleration. There’s also pre-set modes for further personalization, including a quiet ‘stealth’ mode and a louder ‘track’ setting.
05-21-2019, 08:23 AM | #47 | |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
05-25-2019, 01:07 AM | #48 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
I bought my 2017 SS used so I did not have a choice. It had the stock dual exhaust with no NPP and it sucked. I went with a Magnaflow axle back Competition system. $850 for the kit and $100 to install. Sounds great.
