02-03-2023, 07:43 AM | #1 |
Dyno Show Queen LOL
Zl1 1le oem front wheel on zl1
So I took advantage of the Walmart mp4s 325s deal now I'm looking for fronts on the 19x11 oem rim.
305 30 19 is factory lowest price I found 425.00, I found 344 for a 315 30 19 will there be any issues if I go that route to save close to 200 bucks?
02-03-2023, 08:09 AM | #2 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The concern is that you'll be getting very close to the MRC strut with that extra backspacing and the taller 315/30/19 tire (the ZLE doesn't have MRC dampers). With the front 19x11 et11 wheels, you'll have 0.14" more backspacing than the stock 20x10 et20. OTOH, we can fit 305/30/19 on a 19x10 et20 wheel, and that 315 tire is only about 0.4" wider (0.2" per half) and it's center would be moved 0.35" further toward the outside. So the outer shoulder of the tire might actually be further to the outside. You might have to space the fronts out a little bit to clear. Maybe not, though. You'd have to fit it to see. All that said, I'd suggest going with 305/30/19 on the front 19x11. You'll have better clearance, it's a little shorter which will help with handling, it's the stock ZLE size, and it will be a more similar fitment to your rear 325/30/19s relative to the wheel widths.
Matt Miller
2020 SS 1LE |
