01-17-2023, 12:51 AM | #1 |
Drives: Chevy Camaro LT1, BMW M3 Join Date: Apr 2021
Will non runflats work on OEM LT1 Wheels
Its time to switch out the stock goodyears from new rubber.
Will non runflats work on the rims or do I need to stick to run flats? This is my first car with runflat tires so I'm not sure if the rims are a special design that only works with runflats. Thanks in advance |
01-17-2023, 01:45 AM | #2 |
Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
Tires
Yes non run flats will work just fine, only the tires are different not the wheels
01-17-2023, 06:34 AM | #3 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Non-run flats will work just fine.
I recommend putting together a tire repair kit just in case: small case, tire plug kit, extra rubber sement, pliers, and vice grips. A small jack and a lug nut tool are also a good idea. I carry these things mainly when I am on a long trip. |
01-17-2023, 05:50 PM | #4 | |
I guess I have gotten lucky but I've never been stranded from a flat in over 15 years of driving non runflat cars. Whenever I have sensed a slow leak i've been able to top it off enough to get to the tire shop. A fix it kit is a good insurance policy. Knocking on wood I noticed the non run flat michelins are 5 lbs lighter per corner which is a massive unsprung weight savings |
