Old 08-13-2020, 09:18 PM   #1
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Modern Spare
Just wanted to get some ideas on how to secure in trunk...just received today.
https://www.camaro6.com/forums/showt...=528402&page=2
Old 08-13-2020, 10:00 PM   #2
hep4186
Drives: 2017 Camaro 2SS
Picture?
can you please post a picture with the spare in place and the top down when you get it?
hep4186 is offline   Reply With Quote
Old 08-14-2020, 03:41 PM   #3
3Putt
Drives: 2020 SS
I'm new, just bought a 2020 SS Convertible. The first thing I did was take off the run flat summer tires in favor a conventional set of Conti Extreme Contact. I was going to carry a pump and plug kit but this seems like the way to go. I ordered the spare today, anxious to see how it fits and how much room is left in the trunk.
3Putt is offline   Reply With Quote
Old 08-14-2020, 04:16 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
This is how it fits in my 2016 2SS convertible. Space is tight but it fits under the top without touching. Note that the divider has to be disconnected at the bottom to be able to raise or lower the top. Clearance is too tight to be able get the spare in or out with the top down.
Old 08-14-2020, 04:34 PM   #5
50MileSmile
50MileSmile's Avatar
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
Yikes - Does the cover for the spare at least include a slot for your toothbrush in case you’re going on a trip? Otherwise, I guess all you can do is throw your stuff on the upholstered package shelf behind the front seats.
Have you tried using a small magnet at the top right attaching point to fool the lockout so you don’t have to use the divider?
50MileSmile is offline   Reply With Quote
Old 08-14-2020, 09:48 PM   #6
tom's2005gto
Drives: 2016 2SS A8 Convertible
Just to be clear..... this fits under the convertible top, with it down? The divider just needs detached at the bottom? And the spare slid far rearward?
Or?????
tom's2005gto is offline   Reply With Quote
Old 08-14-2020, 11:26 PM   #7
Mark114
Mark114's Avatar
Yes, as shown in the bottom picture.
The divider only needs to be attached to the top posts to operate the top. The pictures show the spare slid as far as it will go toward the back seats.
No, there isn’t much space left after you put the spare into the trunk. The 5th Gen convertibles have more trunk space than the 6th Gens.
Old 08-15-2020, 05:50 AM   #8
Weege
Weege's Avatar
Drives: 2017 2SS convertible M6, NPP, MRC
Is there room for a jack and lug wrench or are we using AAA?
Did you hear about the restaurant on the moon?
Great food
No atmosphere.
Weege is offline   Reply With Quote
Old 08-15-2020, 06:26 AM   #9
3Putt
Drives: 2020 SS
Wow, thanks for the pics! I think I'll go with a plug and pump kit.
Old 08-15-2020, 07:22 AM   #10
Blue_6.2
Blue_6.2's Avatar
Drives: 2019 1SS Convertible
https://www.camaro6.com/forums/showthread.php?t=577787
The magnet defeats the sensor allowing the divider to stay down and the top to function,
Blue_6.2 is offline   Reply With Quote
Old 08-15-2020, 02:01 PM   #11
hep4186
Max diameter difference?
According to the Modern Spare website, the rolling diameter of their spare is 26.5". I have a 2017 2SS with the 6MT so it has a limited slip differential. Wanting to go with a non run flat square setup and get this spare. What is the max diameter differential you can have and not screw up the limited slip? Or, if I got a flat on the rear would it just be best to put the spare on the front and move one of those matching tires to the rear?
Old 08-17-2020, 09:07 PM   #12
Chutzpah
Chutzpah's Avatar
Yep, the spare is pretty tight back there. As far as securing it, I did think of Velcro, but unless it’s sewn on, I’m not certain how well it will hold up. My other concern is that the tire is stuck to the lower panel, which looks like it would be subject to movement, especially up towards the retracted top. I’m going to try and devise a strap set up that will secure the tire to one or both of the styrofoam retainers. Or, I may come up with something else altogether. Either way, I’ll share my thoughts when I know more / have time to invest in this.
Old 08-19-2020, 07:30 AM   #13
In the world of Cell Phones, OnStar and TPMS sensors is a spare tire really that important.
Old 08-19-2020, 07:33 AM   #14
50MileSmile
Obviously, you’ve never had a blowout in a remote area in the middle of the night.
