Old 11-12-2018, 02:29 PM   #211
DANACO
DANACO's Avatar
Drives: 18 ZL1
Received mine this morning
DANACO is offline   Reply With Quote
Old 11-12-2018, 03:58 PM   #212
Staubsauger17
Wisconsin Camaro Pres.
Staubsauger17's Avatar
Drives: '17 Camaro ZL1
E-mail sent to ACS! Awaiting response.
'17 Hyper Blue Metallic Camaro ZL1 Coupe
Staubsauger17 is offline   Reply With Quote
Old 11-12-2018, 04:20 PM   #213
Staubsauger17
Response received - Order confirmed!
Old 11-12-2018, 04:22 PM   #214
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
Received mine too. Nice looking product for sure.
7LitreC5 is offline   Reply With Quote
Old 11-12-2018, 04:40 PM   #215
99BLKBRD
Drives: 2018 ZL1 Mosaic Black A10
Email sent, waiting on reply.
99BLKBRD is offline   Reply With Quote
Old 11-12-2018, 05:23 PM   #216
99BLKBRD
Ordered.
Old 11-12-2018, 07:19 PM   #217
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
List updated.
Please check list to see if info is correct.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 11-12-2018, 08:57 PM   #218
Stealth7
Drives: Gen V Viper GTS
Does installation of the fronts or the rears require drilling new holes or does it used existing holes with the same or different hardware?
Thank you for your responses!
Stealth7 is offline   Reply With Quote
Old 11-12-2018, 09:28 PM   #219
DBelcher
DBelcher's Avatar
Drives: 2018 Camaro ZL1 G7Q
Email sent, reply received, and ordered!
“Only two defining forces have ever offered to die for you; Jesus Christ and the American Soldier. One died for your soul; the other for your freedom.” author unknown
DBelcher is offline   Reply With Quote
Old 11-12-2018, 10:22 PM   #220
DANACO
DANACO's Avatar
Drives: 18 ZL1
To their instructions, you stick the guards in place with the attached strip of VHB tape (3M) then drill holes in the wheel well liner using the holes in the guards as a guide. There are three split rivets that go in the holes for a permanent installation. I’m not too keen on the “permanent “ install aspect of the rivets.
I will look at alternatives that allow me to more easily remove them at will. Perhaps wel nuts, threaded crush inserts or most likely tinnerman nuts as they are very flat and won’t raise the guards off the liner enough to make any difference in fit and will be very secure, even more so than their rivets, they will just require a small slit in the liner where they’ll slip in.
Old 11-19-2018, 12:54 PM   #221
meSSohappy
meSSohappy's Avatar
Anyone else ready to order fronts? Lets get this done !!
Old 11-19-2018, 01:32 PM   #222
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I have the OEM ZL1 rockers on my SS 1LE, I'm going to email them to get a set of fronts though I don't need the rears.
IG: @NC_M1SS1LE
Old 11-19-2018, 02:36 PM   #223
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Received my fronts today
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 11-19-2018, 02:55 PM   #224
waterman
waterman's Avatar
Drives: Grandad's C2 L89
I found a small rock chip in my passenger side door this past weekend. It was inevitable with these sticky shoes.
DANACO, Great ideas on fittment, thanks. I'm interested in your opinions on the alternative fitment option that you have chosen. Can you post a pic or two?
Thanks in advance.
2018 ZL1 1LE sw/PDR
