Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-20-2017, 04:32 PM   #1
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Problem with TPMS
Every time it gets hot out 90+ or I do some spirited mountian driving my right rear TPMS goes out. the tires have been rotated and the sensor has even been changed. The problem is always the right rear.
Does each wheel have a separate reciever? I thought it was a centralized antenna using the keyless entry antenna.
Anyone else experience this issue?
The Bird is the word!
Old 07-24-2017, 03:34 PM   #2
Provy
Provy's Avatar
Drives: 13 ZL1
The battery is probably going low in that sensor. I had one in my CTSV that did the same thing. Just replace it.
Provy is offline   Reply With Quote
Old 07-25-2017, 09:09 AM   #3
Angrybird 12
Already replaced it... all batteries check fine anyway.
Now the error is random, sometimes right rear sometimes left rear... I know unless the dealer can duplicate it they won't do anything. Guess I will just wait till the whole system crashes.
Old 07-25-2017, 09:35 AM   #4
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
I hope you replaced them with OEM TPMS. I've been told of complaints of aftermarket ones.
rvnmaniac is offline   Reply With Quote
Old 07-25-2017, 09:40 AM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I wonder if the issue is with that wheel's hub instead of the TPMS?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 07-25-2017, 09:49 AM   #6
Angrybird 12
Also moved it to a different location, still has an issue with right rear and now left rear. Random error. That sensor is now on the right front.
Old 07-25-2017, 09:51 AM   #7
Angrybird 12
Doubt it...
Old 08-13-2017, 11:39 PM   #8
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Ever figure this out? I have the same issue, anytime the pressure drops to around 32psi the tpms freaks out and says service system. I took it in and was told it was normal. I still have the issue.
danvillekidd is offline   Reply With Quote
Old 08-14-2017, 09:57 AM   #9
rvnmaniac
That's not normal. The one time I did have a nail in a tire TPM came on at about 23-25 tire pressure... I normally go with 34 TP all around.
Old 08-14-2017, 11:08 AM   #10
Angrybird 12
The error has moved to the left front the last several times it came on, but it is so intermittent that until it fails constantly the dealer won't be able to fix it.
Old 08-15-2017, 05:10 PM   #11
Tom And Cheryl
Tom And Cheryl's Avatar
Drives: 2013 SS Convertible, ThumperII
Mine doesn't come on that often but it does and its random. 2 or 3 cycles of the key and its gone.
Tom And Cheryl is offline   Reply With Quote
Old 08-15-2017, 06:28 PM   #12
Angrybird 12
I don't have to cycle the key, it comes and goes randomly.
When it fails the effected tire just shows a -- the rest read normally.
Old 08-15-2017, 06:45 PM   #13
redcoats1976
mine was doing this.dealer finally had to lengthen the wires from the door lovks and get them away from the heater motor.there should be a thread on it in here somewhere,as it took 3 trips to the dealer to fix.
redcoats1976 is offline   Reply With Quote
Old 08-15-2017, 06:46 PM   #14
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
Tpms
Mine work for days at a time,then I'll go over a lateral seperation in the pavement and all four Tpms go off and don't even show on the monitor.A day later the'll be back up.
steakmaker is offline   Reply With Quote
