03-18-2018, 12:10 PM | #29 |
Drives: '18 1SS 1LE Join Date: Sep 2017
+1
I currently run Mobil 1 5W40 Turbo diesel oil in my LS3 due to the improved additive packages. Would be interested in whats recommended for the LT1 which may be in my future. |
03-18-2018, 01:34 PM | #30 | |
Drives: Grandad's C2 L89 Join Date: May 2017
I would also be interested to see if volatility issues of 0W- oils have been addressed in the new Mobil 1 ESP products. I believe this to be an especially important topic when looking long term at the potential intake valve coking and varnishing issues associated with GDI.
2018 ZL1 1LE sw/PDR
03-19-2018, 06:43 PM | #31 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
You guys need to get out more. Here is an official Mobil 1 FAQ that mentions the CTS-V and Camaro along with some specs of the different oils as well. I've used the Mobil 1 European 0W-40 on my 5th gen Z Since I installed the cam, but the new ESP was specifically created for the Corvette.
03-19-2018, 07:43 PM | #32 | |
I have seen the press release from Mobil 1 and the Products Spec sheet. I /we are looking for confirmation from Chevrolet that ESP 0W-40 is (warranty) acceptable for use in the ZL1 LT4. Is 15W-50 still recommended for track use in the ZLE?; or with the new ESP formulation is it acceptable to use 0W-40 for both applications (street and track)? I trust Mobil 1, I am seeking confirmation from Chevy. Oil volatility specs, which are not outlined in the Mobil 1 Product Spec sheet, are especially important to me in a GDI/PCV platform. There is a direct correlation between lower volatility levels and reduced intake valve coking, charge air cooler varnishing and carbon build up in the combustion chamber. All of these will rob us of performance levels over time. The higher the volatility levels, the sooner that it will happen. 0W- oils have traditionally had higher volatility levels, in most cases significantly higher levels than 5W-. Does the new ESP formulation address this? Theoretically, 0W- with reduced volatility gives us the best of both worlds. Low viscosity for reduced wear at start up and higher visc. for reduced wear and protection at higher operating temps. I believe that most in this thread are looking for confirmation from GM that the new multi-viscosity ESP formulation is acceptable over the previously recommended viscosity range. If we are able to transition between street and track with this formulation, as it appears that the ZR1 can. Finally, how does the new formulation address oil volatility at lower viscosity levels?
2018 ZL1 1LE sw/PDR
03-19-2018, 07:47 PM | #33 | |
Drives: 2022 SS 1LE Join Date: Apr 2014
I hope they say we can run it. Makes life much simpler. |
03-26-2018, 11:41 AM | #34 |
Drives: 17 SW 1LE Join Date: Jun 2017
Another question brought up in the 1LE section was about oil temp. Oil temps climb pretty quickly on track but level off and hold steady at 270-275 accoding to cosworth data. I there a reason for this? Is it intentional? Wouldn't there be a benefit to getting oil temps down more and if so how do we do that?
03-26-2018, 12:17 PM | #35 | |
I'm wondering if getting a 160° engine thermostat would help bring down the oil temps. Other solution would be to install an auxiliary cooler and fan, but that causes it's own packaging issues. |
03-26-2018, 01:47 PM | #36 | |
I used to be Dragoneye...
The thermostat is more than likely wide open the whole time, and the resulting temp of 265-275 is the equilibrium that is reached as a result of the relationship I just mentioned. A poorly-designed system will overheat....More heat in, than can be released. A poor system will also shed too much heat, too quickly...remember - oil wants to be at 210 are regular operating temperature, and these things are street cars first.... |
03-26-2018, 05:26 PM | #37 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
ˆˆˆˆˆ
Yes, I'd be more concerned about oil not reaching 210F on the street, then it going to 275F on track. Coming from a C7 corvette, oil wanted to go to 300+ very fast in the Z51 and 310+ in the Z06. It required keeping max RPM in check to do a 20 min session. |
04-25-2018, 09:53 AM | #38 |
Now that the latest question has been answered - we're on the hunt for the most popular/interesting questions...I've got my eye on this one!
04-25-2018, 02:22 PM | #39 |
+1
Interested in Team Camaros' take on Mobil1 ESP 0W-40 for all LT4s, LT1s as well. Al, can you encourage M1 to develop an ESP 0W-50 for summer and warmer climates?
2018 ZL1 1LE sw/PDR
04-29-2018, 09:12 AM | #40 |
Bring It
Yep still watching this one as well. Definitely interested in the clarification on the ZL1 vs 1LE manuals.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
04-30-2018, 09:25 PM | #41 |
Drives: 2017 1ss m6. Blue..... Join Date: Mar 2017
I would like to hear this as well before i spend 80 bucks on oil for my oil change coming up...... I agree with everyone, to many grey areas on selecting the proper oil. What about a lt1 that has bolt ons and is mostly driven on the street and see's alot of WOT in 60 degree plus temps... Starting to think 5-30 is not the best oil for this purpose.
05-02-2018, 07:54 AM | #42 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
Yeah I am interested in this as well. My Camaro is a street car mostly. I know about the new Mobil1 0W-40 ESP oil which is Dexos2, but I stuck with a Dexos1 Gen2 5W-30 when I changed my oil last month considering the change wasn't official for the Camaro yet( and still not to my knowledge as I haven't seen any official GM doc about it).
Considering I drive my Camaro on the street with some spirited driving( no WOT's and oil temp peaking at ~210-220 F according to the gauge), would GM still warranty my car if I decide to continue to use 5W-30 considering as of now the only safe 0W-40 Dexos2 oil for street use is this Mobil1 oil? |
