07-01-2020, 02:59 PM | #29 | |
07-01-2020, 03:58 PM | #30 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The A-pillar covers are just removed for the dash speaker replacement, of course. They only have two attachments, but they are in there pretty tight. I fretted over those more than the door panels. I mostly just pulled them off because I didn't see a good way to use the trim tools at the attachments. But because of that, when they came off, they came out too far and messed up the mics in there. One was reusable, but I had to replace the other. Luckily they are very cheap. You saw my picture of the clip that holds the bungee cord to the trim piece, right? Just wedge that open and remove it. You probably don't absolutely have to take it all the way out, but it would be a lot more of PITA if you don't. There's one bolt for the speaker cover on the drivers side, and that's a small cover that pops right off. The passenger is only one bolt too (IIRC), but the cover goes across almost the entire rest of the dash (it covers the center speaker for the Bose system). It takes a little more finagling, but isn't really tough to remove. One of the dash speakers is easy enough to unbolt with just a 1/4" ratchet and 7mm socket. The other (I think it was the driver's side) requires an open or box-end 7mm wrench to get the bolt by the windshield. No big deal: just go 1/4-1/3 turn at a time, and have patience, and you'll get it out in a minute or two.
Matt Miller
2020 SS 1LE |
07-01-2020, 04:16 PM | #31 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
They slide out, YES its a bitch!!
ZL1::J-E-T-S JETS JETS JETS |
07-01-2020, 04:19 PM | #32 |
Okay, so the dash speakers will probably go in a at later date anyway. I don't have the BOSE system, so I don't have that center speak. However, since that panel has to come off anyway to replace the passenger side dash speaker, would it be possible/beneficial to put one there while I have the dash apart?
07-01-2020, 04:21 PM | #33 |
07-01-2020, 05:42 PM | #34 | |
On the A-pillar trim, I think it would be beneficial to have two people. First, you can use one to pull the trim off while the other blocks it from coming off more than an inch or two (to save the mics). Second, to unclip the bungee one person can hold the trim and pry open the clip while the other pulls it off. That would probably make that stuff go a lot faster. But anyway, you can wait on these. You could even do one corner at a time.
Matt Miller
2020 SS 1LE |
07-13-2020, 06:28 PM | #35 |
So, I haven't pulled the trigger on new speakers yet. It seems every time I'm ready to but something pops up that needs the money first. Priorities. So, anyway, I got to thinking more about this and I was wondering something. Would bypassing the factory amp in my non-BOSE 1SS and replacing it with a better amp make the stock speakers sound better? Or, is the speakers that need to be replaced?
07-14-2020, 07:08 AM | #36 | |
Matt Miller
2020 SS 1LE |
