06-29-2020, 01:39 PM | #1 |
Adding a Sub...help please
Could someone steer me in the right direction on adding a sub to my 2018 1SS? I am exhausted from looking. All I want is a simple/inexpensive way to add some bass to this car because it is almost non-existent. Not looking for a thumping, blow out your eardrums bass, just something to give it some more depth. I've already figured I will need the adapter for the factory amp so that I don't have to cut any factory wires, and I will need the ANC bypass harness as well. But, from there I have no idea. I've seriously been reading and researching what I need but the price adds up pretty quickly. I just want the minimum to get some bass, that's it. I don't know a whole lot about car audio systems, so it's a bit of a learning curve right now and there is SOOOO much information out there I can't wrap my mind around what I should do.
06-29-2020, 03:03 PM | #2 |
So...I think i figured out a way to do it keeping it simple and relatively inexpensive. Has anyone used a speaker box with built-in amp?
06-30-2020, 12:33 AM | #3 |
Drives: Chevy Camaro Join Date: Apr 2020
The cheapest way to do it is a line out, the sub thump harness so you don’t have to cut into the factory wiring, pick a sub and amp you want. Install is easy because the battery is the trunk and you don’t have to run cables through the car
06-30-2020, 09:24 AM | #4 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
You can certainly add a sub. However, you might be surprised at how much really good quality and extended low bass response you can add just by upgrading the factory 6x9 door woofers. I just replaced mine with Audiofrog GS690 speakers and the difference is really night and day. These are not cheap speakers, but they are easy to install with a Metra 82-3017 speaker adapters and Metra 72-5600 speaker wire harness.
I also replaced the dash speakers with the GS25 drop-in replacement, and that is a huge difference in musicality also (since those speakers probably cover 80% of the music range you hear). I'm going to eventually add a small amp with DSP, but in the meantime the sound is already vastly improved, including the bass region. You'd probably get even better results because your car already has a separate (non-Bose) amp in the trunk, whereas my 1LE is only powered by a chip in the radio receiver unit behind the glovebox. I think the vast majority of people who just want to hear music don't really need a sub, and most subs don't have very good sound quality unless you spend a ton of money on both the driver and an amp.
Matt Miller
2020 SS 1LE |
06-30-2020, 10:53 AM | #5 | |
Drives: 2023 2SS Convertible Join Date: May 2009
Thank you. -Geoff
06-30-2020, 11:27 AM | #6 | |
Granted, with no external of any kind, my system as it stands still won't play super loud, but it is improved in that aspect.
Matt Miller
2020 SS 1LE |
06-30-2020, 12:29 PM | #7 |
Thanks for the info. Seems like a great - non-bose solution. I keep looking for small incremental steps on my Bose system, but I think it is going to be an all-in type deal where I have to replace all the amps and speakers all at once. I am out of the bumper-to-bumper warranty, though, so maybe it is time!
-Geoff
06-30-2020, 12:32 PM | #8 | |
06-30-2020, 01:12 PM | #9 | |
Drives: 2020 Camaro RS Join Date: Oct 2019
Maybe this will help with your decision: https://www.crutchfield.com/p_898GS6...rog-GS690.html
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
06-30-2020, 01:57 PM | #10 | |
06-30-2020, 02:16 PM | #11 | |
But if you put a full bypass in of the Bose Amp and then complain about your chime or something, they probably have every right to refuse. -Geoff
06-30-2020, 02:27 PM | #12 |
Also, I’ve read that there is an issue with ANC with some speakers. Would this be a factor with just swapping out the stock 6x9’s for upgraded ones?
06-30-2020, 04:17 PM | #13 | |
06-30-2020, 04:23 PM | #14 |
