Old 06-04-2020, 09:41 AM   #1
RyanR623
Drives: SS A8, NPP, Red Hot
Navigation Head Unit Swap
I have a 1SS with no navigation. Can i just swap the head unit for one with navigation?
RyanR623 is offline   Reply With Quote
Old 06-04-2020, 09:58 AM   #2
Xaxas
Xaxas's Avatar
Drives: 2019 2SS 1LE
You could pay $1200 for an already outdated nav app or you could use the free, included CarPlay or Android Auto, and if you have a 2019+, you're out of luck
https://www.gen5diy.com/products/16-...grade-8-screen
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire"
Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros)
Xaxas is offline   Reply With Quote
Old 06-04-2020, 10:09 AM   #3
RyanR623
I get GM service parts at cost. I have a 2017. I'm not tech savvy so i have zero idea what carplay or android auto is. I'm assuming it's an app that connects the navigation on your phone to your head unit? Just seems easier to have it already in your head unit.
Old 06-04-2020, 12:21 PM   #4
Xaxas
Xaxas's Avatar
Exactly, just plug your phone in, and read your users manual or look up a video, you already have this in your car
Old 06-04-2020, 12:31 PM   #5
RyanR623
Will do, thanks for the help
Old 06-04-2020, 04:00 PM   #6
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
It can be done. You must swap the HMI module for one w/nav and add a GPS antenna. The HMI must be programmed for your VIN and then it becomes an orphan, by that I mean from then forward it won’t match up at the dealer so you can’t let them “reflash” the HMI.
All will work with the exception of having the posted speed on the HUD
You get turn by turn symbols but no posted MPH. That can be had at the cost of removal of the instrument cluster for additional programming. Personally, I don’t miss it.
I hope this helps!
Sweptwing is offline   Reply With Quote
Old 06-05-2020, 12:04 PM   #7
RyanR623
I hope this helps!
It does help, thanks. Not worth it lolol
