05-10-2020, 05:17 AM | #15 |
MT lists the 305/45-17 that the OP was talking about as a 28.1 diameter, which is definitely taller than the stock SS tire. I have seen the effect of the taller tire in the data, an unadjusted speedometer reads lower with the taller MT on it. I have had both tires on the car, the difference is noticeable.
05-10-2020, 08:02 AM | #16 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
Sent from my SM-G955U using Tapatalk |
05-10-2020, 08:07 AM | #17 | |
05-10-2020, 02:10 PM | #18 |
Drives: 2018 Camaro 2SS A8 Join Date: Dec 2019
Thanks guys,
When I toss the ET Street's on this week sometime I will take a measurement of them sitting at 20psi on the car vs the stock wheels on the car sitting at 32psi and post it up here for reference. If there is any difference I am sure my OCD will have me make a 2 second adjustment in HPTuners for it.
2018 Camaro 2SS A8 Redline Edition
05-10-2020, 03:08 PM | #19 |
That is just generic stuff there, using nominal sizes like that. Perhaps you didn't realize it, but not all 275/35-20 or 305/45-17 tires are actually the same size just because it's stamped on the sidewall. I have scanned the car on the track using both the stock SS runflats, and the MT 305/45-17 tires that are the subject of this thread. What I saw was that with no change in the speedometer calibration, the MTs gave lower readings on the speedometer than the runflats did. Real speeds were known because it was done on a track. Dropped a lot more than half a mph in the reading going to the taller MT. Tire pressures were 27psi for the runflats and 17psi for the MTs, and yes, this means that the MT was made a little shorter by that lower pressure. If you ran a lot of air in the MT then you'd likely see an even bigger difference than this.
05-10-2020, 04:15 PM | #20 | |
05-10-2020, 04:24 PM | #21 |
So I played with this calculator to get it even closer to the actual tire height of 28.1 Mickey Thompson says and it will be off by 1 mph, like I said not even noticeable.
05-10-2020, 05:09 PM | #22 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
You can get away with not scaling and be ok, for informational purposes the ecu reads the factory tire height at 26.83 so changing the tire height to 28 will net you a difference of only 1 mph on the 1-2 upshift parameter and it's scaled to 4 mph on the 4-5.
05-10-2020, 07:05 PM | #23 | |
That was my main concern I had with the tire scaling affecting the trans shift points. I haven't sent in my TCM to be unlocked yet so I dont want to make the problem worse.
05-11-2020, 07:11 AM | #24 |
Your 731 revs/mi figure for the stock runflat is taller than it really is. The factory calibration is 745 or 748, depending on the model year. By calling the runflat taller than it really is, that makes it seem like the 2 tires are closer than they really are. The true difference, as I've track-tested, is larger than you are portraying. Was not talking about whether you notice it driving on the street with no benchmark, only talking about the true size difference. Whether someone wants to work on their calibration for this tire or not is of course completely up to them.
05-11-2020, 04:17 PM | #25 | |
05-12-2020, 08:24 AM | #26 | |
