11-30-2016, 10:50 AM | #15 |
Drives: 2017 SS 1LE Join Date: Mar 2016
It's definitely possible, it's just a question of how difficult will it be.
IG: @NC_M1SS1LE
11-30-2016, 10:53 AM | #16 |
I used to be Dragoneye...
Yes.
11-30-2016, 11:45 AM | #17 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Post #6 shows the standard deflectors. This is my SS track deflectors and ducting:
11-30-2016, 11:46 AM | #18 |
Sorry, upside down
02-02-2017, 11:09 PM | #19 |
Drives: 16' Camaro E-Force SS Join Date: Jul 2016
Questions for you guys, because it's not super clear to me.
The 1LE just has the SS brake ducts installed from the factory, is that correct? Or are they different? Anyone have part numbers (i looked couldn't find ones for 1LE)? For a non-daily SS that never sees rain, is there any danger into leaving the ducts on full time like the 1LE? |
02-02-2017, 11:38 PM | #20 | |
No risk with rain. There's a heat exchanger in there that will let water through, as well. The cars were tested for quality and durability using the same foul-weather/ice/water tests as a Malibu or Silverado might see. One thing to note - brakes tend to get a little slippery when driving on the highway in the rain for long periods of time. Since the brakes aren't used, they get a little damp...and the pads need a split second to push through that water. |
02-03-2017, 12:23 AM | #21 | |
02-03-2017, 07:50 AM | #22 | ||
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
The SS has tire aero deflectors. The SS 1LE has no tire deflectors at all. Likely this is because the 1LE sits lower and they won't fit. Their only purpose is to improve aero when highway cruising. The SS has large brake cooling deflector shields that mount to the contol arm to deflect air to the Rotor. This works in conjunction with a separate backing plate for the rotor that has a large opening to allow air flow to reach the rotor surface. The SS 1LE has the backing plate with the opening just like the SS track kit, but the control arm shield is trimmed down, but shaped in more of a scoop fashion. So the main difference is that the SS track kit is designed to maximize the cooling on a car with a higher ride height. This same kit would likely be useless on the 1LE because the shields would likely drag a lot during street use. So if I owned a lowered SS I would look into removing the tire deflectors and permanently installing the backing plates and trying to purchase the 1LE/ZL1 brake deflector sheilds. That way you can just track the car without having to swap out the deflectors all the time.
MJK3888 Instagram Link
02-03-2017, 08:56 AM | #23 |
Mack da M1SS1LE
Drives: 2017 Summit White 1SS 1LE Join Date: May 2015
I manage to get my dealer to send me the SS Tall Deflector and Small Splash Shield. We both weren't sure if the 1LE was supposed to come with them. I got them for free. I now know that I don't need them, you can figure out what I will do with them.
The "G" SEEKING M1SS1LE
02-03-2017, 09:02 AM | #24 | |
02-03-2017, 09:22 AM | #25 |
"M1SS1LE"
I'm sorry I didn't. If I'm under there any time soon I will.
02-03-2017, 10:13 AM | #26 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
The ducting for the brake cooling comes from the cover with the LED light, NOT from the ducting with the supplemental radiator.
02-03-2017, 10:18 AM | #27 | |
The brake cooling duct is actually located in the inner lower grille, as shown in the image above. The bit near the LED daytime running light is an "air curtain", and doesn't duct to the brakes at all. |
02-03-2017, 10:24 AM | #28 | |
"M1SS1LE"
