03-24-2019, 12:59 PM | #15 |
Drives: 2010 SS L99 Join Date: Sep 2018
he's not very active anymore here since his surgery. Good luck to you
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
03-24-2019, 01:26 PM | #16 |
Drives: 2011 2SS RS Black Vert Join Date: Nov 2013
Whichh Powerbond pully are you guys running? There seems to be more than one choice.
03-24-2019, 11:03 PM | #17 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Hopefully you replaced the one time use damper bolt and consider rechecking the torque of the bolt as well. I’ve seen them back out.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-26-2019, 04:08 PM | #18 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
Yes it was replaced, I just got fluidampr 760111 and a crank bolt. The harmonic balancer is heavy for what it is. I will be using a chrysler crank pulley removal tool since is easier. Thanks everyone
03-26-2019, 04:15 PM | #19 |
I have the Powerbond 25% underdrive
03-26-2019, 04:17 PM | #20 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
excellent. took care of it before it took car of your hood! some dampers require a different length belt, btw. id check that out too so that your install goes smooth
Bone Stock |
03-28-2019, 07:04 AM | #21 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
I am still around have to go back to work Monday damn...LOL well no rest for the wicked. 428 stroker I bought from SAG performance, they sell engines as custom engine supply, a guy named jerry the machinist on EBAY in Indiana ; they ship for free anyway, used Molnar rods and crank racetec pistons ...big names, Molnar makes the other guys you know named parts,.... Racetec guy owned JE Piston..... basically stuff with the most dependable parts by the highest volume short block guys clearanced and done up right sent to my tuner Tommy Wong the best out here. Bought a MAST stroker windage tray for it; still had to clearance it more for the stroke, picks up about 50 ft lb from stroking all across the board, worth it. Most do a 416. I am at 11:1 compression pump gas daily. good luck. I am still recommending the powermaster starter it works soooooo much better than stock when hot..... and even not....
03-28-2019, 07:34 PM | #22 | |
-Scott |
03-30-2019, 10:18 AM | #23 |
They provided a brand new block, I paid 5k.....forged, stroked, clearance, correct engine oil plugs etc stock ls3 bock bare is about 1400$ add 2500 for forged internals......aftermarket blocks that can be resleeved much more $$$ ls3 blocks do not get resleeved they are a trashed block with sleeves cast in and can only be over honed .020 a ls7 can only go .005....never buy one of those; basically its ready to be overhoned and that's it for aftermarket pistons new with a ls7 which usually requires .005 to clean things up for the pistons to go in with their dimensions. One reason you can find a spendy ls7 used for fairly cheap.....its block $$$$ and trashed most likely......
