08-13-2020, 12:27 PM | #1 |
lost between two shores
Drives: 2020 SS 1LE Join Date: Apr 2018
Apple CarPlay Shortcut
I did a quick search to see if this was mentioned and didn't see anything, but also didn't spend a lot of time. It may also work the same with Android??
When wanting to switch from your current screen to CarPlay, hold the Home button (the house) down for about 1 full second.
2020 SS 1LE | Almost Mod Free
08-13-2020, 01:31 PM | #2 |
Drives: 1SS 1LE Join Date: Mar 2018
Nice will try when I get back in! Pretty nifty.
Another shortcut if your using the regular interface (GM) and your listening to music, swipe to the left with a finger and it will put your cluster in audio mode/display.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
08-13-2020, 08:41 PM | #3 | |
I just re-read what I wrote and saw I left off the word "second" (1 full second). Guess you figured it out. lol Thanks for the tip - I'll give it try.
08-14-2020, 07:43 AM | #4 |
Hot Camaro
If the Home screen is displaying a single screen of info (music, home screen, etc.), a quick click of the Home button will change to music on the left with the phone below it and navigation (built-in) mini-map on the right. From this mini screen, you can tap any of the three areas to get to those respective screens.
A long press of the Home button, regardless of what's on the display, will switch to your connected phone for either Apple CarPlay or Android Auto. If you leave the main screen in the three-pane view, and click the Home button while in the Android Auto or CarPlay screen, you will return to the three-pane view. Otherwise, a click of the Home button will return you to the main home screen. |
08-14-2020, 08:54 AM | #5 |
LT1_Radenso
Drives: a 2 spd water bottle Join Date: Sep 2017
Pfft, lucky SS owners.
08-14-2020, 09:28 AM | #6 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
Nice tips thank you
