05-19-2020, 02:05 PM | #1 |
Drives: 2017 Arctic Blue Metallic A8 SS Join Date: Mar 2017
A8 haunted?
I check this section of the forum daily....well, because I have an A8. Have not seen this issue come up before.
This morning after driving 15 miles in automatic, and in touring mode, I put the hammer down to enter the freeway. It kicked down into third and at the top of third it hit the limiter, and the 3 appeared as if in manual mode. I looked at the shifter and touched it. Yep, in automatic position, all the way to the right, but yet the 3 was showing. It would not upshift. I quickly moved into the slower lanes and reduced speed to about 50. Then finally the 3 went away as it slowly/lazily upshifted to 7th or 8th. After that I had no problem, and it shifted crisply in both manual & automatic modes. I drove another 16 miles trying to replicate and it did not. No code/warning lights, just normal great performance as always. The car is stock & never been tuned, and has performed flawlessly until this morning. No shudder to date. 6400 miles. Anyone ever see this happen? Shifter was positively in automatic position. Still under drivetrain warranty, but at this point I'll bet the dealer will never be able replicate. |
05-19-2020, 02:11 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
Were you accidentally touching the downshift paddle? It will temporarily put the transmission into manual mode even when the shifter is in automatic mode.
05-19-2020, 02:29 PM | #3 | |
With hands at 9 & 3, it is possible. Would much rather have this as human error than malfunction. Food for thought. Thank you, Mark If no one else posts that they've seen this happen, I'll more than likely chalk it up as just that, and be more careful.
2017 SS Arctic Blue Metallic A8 GM big brake kit SG3 Lowering & FE4 sway Bar Kits
Thread Tools | |
