Vararam
Old 02-29-2024, 02:24 PM   #1
Kxm
Drives: 2013 Chevrolet Camaro 2SS/1LE/RS
Cam Swap Quote - Is this accurate?
I reached out to a local shop and they provided me with this quote. Is this accurate or overpriced?
Kxm is offline   Reply With Quote
Old 02-29-2024, 03:53 PM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
That's competitive pricing.
joshnmn is offline   Reply With Quote
Old 02-29-2024, 05:02 PM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
seems reasonable.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 02-29-2024, 06:59 PM   #4
AlisoBob
Drives: Camaro 2SS Gen 5
Whats the goal??
AlisoBob is offline   Reply With Quote
Old 02-29-2024, 08:33 PM   #5
Kxm
Originally Posted by AlisoBob View Post
Whats the goal??
Here is my original quote request:
To whom it may concern,
I am reaching out to request a quote for my 2013 Camaro SS 1LE to swap out the cam, valve springs, push rods, supporting bolts and gaskets, and would like to hear of any other suggestions to replace while swapping it as well. I'd like to put a big cam in it that has a significant lope. Of course I would need a dyno tune included as well. I only need it tuned on 93 as I am not running E85.
It currently has a Cold Air Inductions cold air intake and I am putting on 2" Texas Speed long tube headers this upcoming weekend.
If you could shoot me over a quote breaking down the cost of the material and install I would appreciate it. Also if you could specify would brand and size cam you recommend that would be helpful as well.
I am from out of town, I am about 15 minutes north of Louisville, KY. If you could provide a lead time on the install so I could plan my travels I would greatly appreciate that as well.
I look forward to potentially doing business with you!
Thanks,
Old 02-29-2024, 08:34 PM   #6
Kxm
10-4
I read through a couple of threads on here and people were talking about pricing being in the 2500-3000 range. Times have changed and I was unsure about the market nowadays.
I appreciate the input everyone.
Old 03-01-2024, 02:49 AM   #7
AlisoBob
Dont see any lifters..... are they tossing them in for free?
Old 03-01-2024, 06:51 AM   #8
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
It's higher than I paid in 2019, but so is everything else. That's probably not an outrageous price in today's market.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 03-01-2024, 07:54 AM   #9
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
Instead of getting a cam with "significant lope" you could get one with significant power gains?
Either way, you will probably need a higher stall torque converter.
gtstorey is offline   Reply With Quote
Old 03-01-2024, 09:12 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
For this day and how things are cost wise, looks like a pretty good price for the job, also as stated, didn't see any lifters listed. Good luck.
1JEWLDSSRS is offline   Reply With Quote
Old 03-01-2024, 10:56 AM   #11
62nalide
62nalide's Avatar
Drives: 2013 SS
That's pretty good IMO. I personally wouldn't price shop rather have a shop that knows the platform vs one that doesn't.
62nalide is offline   Reply With Quote
Old 03-01-2024, 01:00 PM   #12
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yes this for sure. It's the most important thing about the shop performing the work. I would look for a shop with good google reviews and not necessarily a big shop just one that you can ask questions like how long will you stand behind your work and they give a legitimate answer. Also ask them if they will pay for the labor if something goes wrong from a part that they installed. And the dyno tune is important but not a deal breaker either because you can always get an email tune from an experienced tuner on the hp tuners forum or a well know place. And like gtstorey said you will need a higher stall converter and a transmission cooler with that big of a cam.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-01-2024, 02:35 PM   #13
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
They give 23 hours for a camshaft replacement. At $2500 that only $108 an hour, That's a good hourly rate. $130-$150 an hour is common. Also I agree with others about the shop doing the work/Knowing the platform.
Mouse330 is offline   Reply With Quote
Old 03-01-2024, 05:07 PM   #14
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Line #1: DOD conversion. You're 1LE so manual transmission ergo no DOD lifters. Probably no biggie but little stuff like that always gnaws away at me. Definitely a fair price if it's a reputable shop.
I just reviewed the estimate again. No head gaskets so no head removal. I'd kinda like new/upgraded lifters with my cam especially if I'm forking over a good chunk o' cash.
ariZona28 is offline   Reply With Quote
