Old 05-21-2022, 01:23 PM   #1
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Has Anyone Changed Their Center Support Bearing on Driveshaft?
So after thinking I had something rolling around in the trunk on hard takeoff and while turning in first on the gas hearing thumping. I figure out with pretty high confidence that I've finally killed the stock flimsey center support on the Driveshaft.
It looks like once I get the drive shaft out I may have to press it out of the bearing to put the new one on? Not sure though?
It looks like GM has updated it to a new part number 84255731, so hopefully they made it stiffer and stronger. Hopefully it improves the POS sounding rattle/knocking when going from drive to reverse to neutral.
cmitchell17 is offline   Reply With Quote
Old 05-21-2022, 05:49 PM   #2
cjperformance
cjperformance's Avatar
Consider replacing w a one piece ds.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 05-23-2022, 12:50 PM   #3
cmitchell17
I would but it's hard to justify the price. I hate the clunking and noises but I would rather deal with it and keep replacing supports than spend 1500.
I haven't been able to find anyone who has bought a ZL1 driveshaft for a automatic. I think a ZL1 Driveshaft will work for a manual but not sure for an automatic. Although I guess it would still probably have the same problem, but I've never driven a ZL1 to confirm.
Old 05-30-2022, 08:13 PM   #4
cmitchell17
So I put a new one on. I had bought a brand new shop press since I figured I needed one for other things and I went to try to put the drive shaft under it and the u joint yoke was too big to fit under the hole between the steel beams in the press. So the press basically was useless for this job. I bought the 20 ton harbor freight one and it was just barely too small.
I ended up getting the bearing off with a 12 dollar jaw gear puller it wasn't on that hard of a press fit.
I tapped the new one on with a pipe.
Old 05-30-2022, 09:22 PM   #5
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. The factory SS driveshaft if very weak at that point where it meets the center carrier bearing. For evidence, I submit exhibit A to the court:
Old 08-09-2022, 11:12 AM   #6
asthmamax11
asthmamax11's Avatar
Yes had this replaced under warranty a few years ago
They tried to blame it on my DSS axles and replaced them with OEM also
Bastards probably sold them on ebay
Still mad about it 4 years later
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
