03-30-2019, 12:39 AM | #1 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Our 2010 SS Blew Up!!
Driving on the I-4 freeway today driving into St.Peterburg,Florida in our 2010 SS I was doing some spirted driving when I would see openings in traffic I heard a unknown metal knock noise and then one or both cylinder head gaskets blew. I could not get over because none of the drives on the I-4 would let us over so I had to keep driving and then our 2010 SS died and would not start back up. I looked at the L99 and I seen motor oil seeping from the side of the passenger side cylinder head and when it cooled down I opened the radiator cap and I seen oil mixed with coolant mess. The L99 is currently at 151K miles. Before about approximately 10K miles about I read the spark plugs and found slightly thick oil residue on the threads of cylinders 1,3,6,7,8. Also found a very small hair line crack on the piston in cylinder #6,excessive wear on the cylinder head valve guides,and excessive oil residue inside the intake manifold. I would notest slight oil burning coming from the exhaust and using some motor oil between oil changes. I cleaned the inside of the intake manifold the best I could and even put everything back together. I am looking for bright ideas for a rebuild on our L99 engine? Opinions? Right now our 2010 SS is dead in the driveway as I had to get it towed obviously.
Mr. Clean
03-30-2019, 04:27 AM | #2 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Use car-part.com and get a low mileage replacement, or tear it down and build it from scratch.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
03-30-2019, 10:13 AM | #3 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
quality crate engines available online just search.
03-30-2019, 11:59 AM | #4 |
Thanks I seen a few long blocks I like from TSP.
Mr. Clean
03-30-2019, 12:28 PM | #5 |
I am liking the 408ci from TSP.
Mr. Clean
03-31-2019, 09:38 AM | #6 |
http://www.sagperformance.com/Online-Store.html
I used these guys called custom engine supply they are on EBAY the machinist is Jerry very helpful when you can get ahold of him in Indiana, ships free, and like TSP use br30 to break the engine in. Good Luck.
03-31-2019, 07:59 PM | #7 | |
Mr. Clean
04-09-2019, 08:50 AM | #8 |
Drives: 2016 SSupercharged, 2012 Camaro SS Join Date: Sep 2016
Check this one in the member market place, new $5,695
https://www.camaro5.com/forums/showthread.php?t=543514
04-09-2019, 09:25 AM | #9 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
821 = hollow intake valves = LS3 heads I wonder if the later L99's came with them like that
Bone Stock |
04-09-2019, 09:32 AM | #10 | |
https://www.texas-speed.com/p-1020-t...-assembly.aspx and talk to GPI about one of their VVT cams for this setup
Bone Stock |
