Vararam
Old 02-13-2019, 10:24 AM   #1
awsm66
Drives: Victory Red 2011 2SS
Made my own shifter for my auto.
I saw Elvis66 posted a White Madness shifter a week or so ago and decided I would order one. I already had a manual shifter boot in the car but was using the stock shifter.
I put the White Madness shifter in and while it is a great design and well thought out and great finish, I wasn't happy with how it looked with the manual shift boot.
I was going to make an adapter for the boot but then decided to just make my own shifter instead.
I took some 2.5" solid AL stock I had and started turning it down until I had my desired shape. Then I figured out the actual length and cut it to size. Then I hollowed it out and tested it to make sure it worked like I wanted it to. Next step was to machine a piece of delrin as a bushing to the metal on the shifter so I wouldn't have metal to metal rubbing. I threaded it for a 12x1.25 because I couldn't find a CF ball I liked in the 12x1.75 thread. Lastly I milled a slot in it and turned down a screw to hold it all in.
I am not quite finished but far enough along to share what I have. I will be ceracoating the screw head with "micro slick dry film coating" to help with any seizing but I don't think it will be a problem if I didn't...I just would rather do it just in case.
I am NOT a professional machinist, and I wouldn't even say I am a hobby machinist...I am more of a "I got a good deal on some big machines from a friend and I like to play and use them some" machinist LOL. I used to use them a good bit to make collectible lightsaber hilt parts and even entire hilts but I haven't used them in quite a while so it was fun to use them again.
The shifter ball I ordered will hopefully be in on Thursday or Friday and I will update the post when I have that pic. Until then here are some progress pics.
OK all the images are rotated...sorry about that but I do not know how to fix it.
awsm66 is offline   Reply With Quote
Old 02-13-2019, 10:52 AM   #2
grammy
grammy's Avatar
Drives: 2016 SSupercharged, 2012 Camaro SS
Please put me at the top of the list if you decide make some more. Extremely interested.
Thanks
http://farm6.staticflickr.com/5720/30104655851_a039fce211_h.jpg
grammy is offline   Reply With Quote
Old 02-13-2019, 11:19 AM   #3
Caniac27
Caniac27's Avatar
Drives: 2016 Chevy Colorado, Red Rock
Following as well. Already have the manual shift boot upgrade. Liking what i see here.
2016 Chevy Colorado (Daily Driver)
2013 Camaro 2LT/RS (Traded 2020)
Caniac27 is offline   Reply With Quote
Old 02-13-2019, 11:24 AM   #4
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
Would like to be 3rd on the list! Looks Awesome!
Junior is offline   Reply With Quote
Old 02-13-2019, 11:35 AM   #5
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Nice job
JD555 is offline   Reply With Quote
Old 02-13-2019, 11:49 AM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Very clean and well made, wish I had your skills, came out awesome!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 02-13-2019, 12:10 PM   #7
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Fancy! Nice work
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 02-13-2019, 02:18 PM   #8
Lou gill
Lou gill's Avatar
Drives: ‘13 ZL1 convertible
A true artist
Lou gill is offline   Reply With Quote
Old 02-13-2019, 03:13 PM   #9
awsm66
Thanks everyone. I do not have plans to make anymore right now. It doesn't look like much but it was several hours of work on my manual machines and I have several projects going on right now (I work full time and run a side business).
I will speak with a friend of mine that has a CNC machine shop and see if its feasible to take my design and machine it but he is pretty swamped as well so I am not sure its something he would take on.
Old 02-13-2019, 03:15 PM   #10
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Beautiful work. I wish I had your skills.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 02-13-2019, 04:27 PM   #11
grammy
grammy's Avatar
Great work man, would really like to have one if you decide to move forward and build a couple more
Old 02-13-2019, 05:26 PM   #12
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
Very nice work, looks great .. well done
Welker2 is offline   Reply With Quote
Old 02-13-2019, 06:39 PM   #13
orange devil
Drives: 2019 SS 2019 mustang GT
Great job!!! Looks great .so after playing with the shifter I found away to adjust the boot.. simple zip tie inside the boot .. really like how yours turned out it's much more like the white madness did for automatic mustang..
orange devil is offline   Reply With Quote
Old 02-13-2019, 06:48 PM   #14
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Nice work!
