05-13-2016, 10:17 PM | #29 |
Moderator.ca
Tell that to the Nascar boys that run their pushrod engines at 9000+ RPM. Then again ... those engines only ever have to last a few hundred miles. Maybe thats a bad example.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-13-2016, 10:24 PM | #30 | |
Drives: 2016 Black Camaro 2SS A8 Join Date: Apr 2016
It makes sense to try stuff out it the Camaro first, work the bugs out. |
05-13-2016, 10:24 PM | #31 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I'm pretty sure the NASCAR guys run solid lifters too and not hydraulic lifters that production cars run. But the NASCAR teams have the time and ability to adjust the valve lash when needed. Not many people are going to want a production street car that they have to adjust valve lash on all the time. The hydraulic lifters are the limiting factor in the RPM ranges.
05-13-2016, 10:32 PM | #32 | |
Moderator.ca
05-13-2016, 10:44 PM | #33 |
Moderator.ca
I just noticed that in responding to others comments in here ... I failed to actually discuss the topic at hand. Whoops, mods are supposed to keep threads on track -not derail them.
Anyway, I agree with pretty much everything that the Motor Trend guy is saying. Although it doesn't need to specifically be a 7L engine. I could see GM going with something a little bit smaller to alleviate issues that the 7L displacement caused for the LS7. Backing off just a hair could allow them to build an engine thats more conventional & therefore good bit cheaper while delivering almost the same performance. I'm thinking a 6.8L -ish engine might strike a good balance, though I have absolutely nothing to base that on other than gut instinct.
05-13-2016, 11:02 PM | #34 |
Drives: 2015 Porsche BGTS, 2016 2SS Join Date: Oct 2013
Yea, I know the FPC was a non starter, just like the design.
Tadge, the Corvette chief engineer said point blank the LS7 was dead from a production standpoint 2 years ago due to corporate fuel economy directives and emissions. That doesn't mean they haven't developed a "new" member of the LT DI family with more than 6.2L displacement that can play in the mid 500 HP range. |
05-13-2016, 11:24 PM | #35 |
Drives: 2016 Camaro 2SS M6 Black Join Date: Nov 2013
OR! (Just remembered about this bad boy) a DI 5.3L N/A motor like was first speculated for the c7 corvette and i believe is in one of the c7 racers.
05-14-2016, 01:58 AM | #36 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Fair point. I should clarify. A production push rod V8 with a 100k warranty in a car that costs less than $100k could not take advantage of the flat plane crank.
05-14-2016, 02:55 AM | #37 |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Good thing GM only offers 60k warranty.... ?
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
05-14-2016, 03:02 AM | #38 |
Does the LS7 have a different firing order than the LT1?
05-14-2016, 06:45 AM | #39 |
Drives: 2019 GT350 Join Date: Jan 2011
Anyone who thinks GM isn't capable of building a 7.0 liter motor capable of besting the GT350R in this new Z/28 is smoking crack or has their fanbois head so far up their backside they can't see daylight. Voodoo
The Ford camp needs to stop worrying about the Z/28 and ZL1 and worry about the 1LE which is going to give them all they can handle.
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
05-14-2016, 06:49 AM | #40 |
Drives: everyone crazy... Join Date: May 2009
05-14-2016, 06:49 AM | #41 |
Drives: 2SS '16 Camaro Join Date: Apr 2016
GM isn't going to put a prior gen engine into the next Z28. They probably will offer a different displacement LT series in the Z28.
So, either a 7.0L for the 427 cool factor or, more interestingly, maybe a LOWER displacement spinner. 5.5L spinning to 7500-8000rpm and making 530-540hp with a 10 speed to keep it in the meat of the power band. How awesome would that sound?
'16 2SS White/Adrenaline Red Coupe Mag ride, 8-speed, Sunroof, Dual-Mode Exhaust, Black wheels
Also: 2010 ZR1 2018 GT3 2013 LX570 |
05-14-2016, 06:52 AM | #42 | |
