07-23-2019, 06:16 AM | #1 |
Drives: ZL1 1LE Join Date: Jul 2019
Open trunk? Battery disconnected?
Help! I did disconnect the plus cable in the back and closed the trunk on my 2018 zl1. How do i open it now? Car is open and engine bay is open.
How do i open the trunk? |
07-23-2019, 06:23 AM | #2 |
Maybe crawl through the back and grab the emergency latch pull.
07-23-2019, 06:57 AM | #3 |
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
crawl through the back and release the latch, press really hard pushing the trunk upwards. if your doors are locked then make sure you open the key fob and take out the key, you'll see a key hole where the key goes under the door handle.
Well............ At least you tried. lol
07-23-2019, 08:21 AM | #4 |
Drives: all sold, getting another soon.. Join Date: May 2019
I have a funny feeling this will happen to me someday. I will NOT fit through the pass through.
Larry
07-23-2019, 08:23 AM | #5 |
07-23-2019, 08:34 AM | #6 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
Possible to connect another battery to posts under hood? DOnt know if that would work or not...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
07-23-2019, 08:52 AM | #7 |
Drives: '19 2SS M6. Join Date: Aug 2018
Why not disconnect the battery from under the hood?
If I’m not mistaken, the positive and negative battery connection come straight from the battery in the trunk. please correct me if I am wrong.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
07-23-2019, 09:07 AM | #8 |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
Some of the guys are asleep or punking you...LOL
Just connect a battery jump pack or charger to the post under the hood, the car will come back to life and you can use your remote or the button under the bumper...
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
07-23-2019, 09:17 AM | #9 |
Even if the battery in the back is disconnected?
07-23-2019, 09:39 AM | #10 |
Yes, You're just putting 12VDC on the system which will power up the car's electronics. Don't try and start it just pop the trunk lock. It will not hurt anything.
There is a positive post by the fuse block (covered by a red cap) and ground post under the hood on the passenger side.
07-23-2019, 11:31 AM | #11 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
I feel like crawling back through seat and opening the trunk is easier than hooking up jumper cables.
07-23-2019, 11:37 AM | #12 |
Retired from Car mfrs....
I always found it uncomfortable to climb through that back section so I made a tool to open the door. Just go cut a broomstick and at the end, tape on a hook cut from a coat hanger, Ducttape a flashlight to the end, stick it through, and pull back, works perfect.
07-23-2019, 12:37 PM | #13 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
The line to the rear fuse box will still be connected when you disconnect the line under the hood.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
12-14-2021, 09:43 AM | #14 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Thread resurrection, for future reference.
I had to disconnect the battery on my ZL1 because I was leaving for a trip. So I tied a cord on the emergency latch pull inside the trunk, I dropped the rear seats (yes, they drop in the ZL1) and when I return, all I have to do is simply pull the cord to open the trunk.
Mosaic black 2018 Camaro 2SS A8 (sold) |
