Old 07-22-2019, 11:28 PM   #15
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
How can you tell how close a SC3 tire is to cording before it actually cords?
I'm trying to plan ahead and figure out if I'm going to get a 5th track days out of these tires or not.... the track is tough on tires, lots of turns and cornering, not much straightaways.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 07-23-2019, 06:49 AM   #16
TrackClub
TrackClub's Avatar
Good question, but one that doesn't have a reliable answer imo. If you cant see any cords (even tiny ones) on either edges of the tires, no reason not to continue tracking them (unless you are concerned with wet performance, but that's a different consideration). But check them after each run (a good idea regardless of tire age) and get a new set, as G3s seem hard to come by for some reason, at least in the East.
While some tracks are harder on tires vs others, note that tires undergo highest loads in fast sweepers. Quality of pavement also makes a big difference. Older tracks will be harder on tires, as asphalt wears out and pavement becomes more abrasive. Driver also makes a big difference re tire wear, if he/she slides the car much.
Finally, camber affects wear as well. Too little and outside will suffer more. Too much and the inside will.
A track friend with a ZL1 on brand new G3Rs killed his outside front in just over ONE DAY right down to steel carcass (which was shooting sparks!), last weekend with 3++ camber (cant recall exact spec, but it was tons).
So, no precise answer, as i am not aware of one, but some food for thought. Cheers
Old 07-23-2019, 02:10 PM   #17
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
If they don't look close to this you are good to go
Old 07-23-2019, 04:48 PM   #18
Badmojo
aka BeastZL1
Badmojo's Avatar
Grip will start to fall off slightly after 15-20 heat cycles and wear. My lap times drop 2-3 seconds before they start to cord. Corner exit traction starts to go first.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 07-23-2019, 05:09 PM   #19
TrackClub
TrackClub's Avatar
Thats because you have 650hp and tq LOL
My laptimes fall off slightly but still within 1 second on a 2+ min lap. G3s are a stout tire. Perhaps G3Rs fall off more?
Old 07-24-2019, 12:10 AM   #20
GunMetalGrey
Thanks for the answers guys, much appreciated, learning lots!
heat cycle, sc3, tire, track
