07-17-2019, 06:17 PM | #1 |
Drives: Chevrolet Camaro ZL1 Join Date: Jul 2019
OBD-II PID's for PDR
That's a lot of acronyms!
I've jumped down the rabbit hole of datalogging my races. I use RaceChrono with the OBDLink MX+. I know next to nothing about PID's but I understand there is a "standard" set and then a super secret, manufacturer specific list of custom PID's. The standard list has everything I want except the brake pedal position. Gear position would be a bonus (M6 transmission). Does anyone know the super secret codes and can explain in lay terms how to show the brake position? Obviously the car records and logs this data because you can see it on PDR video. PS, my car does NOT have PDR. 2018 ZL1 M6. Thanks! Ryan |
07-28-2019, 12:51 PM | #2 |
OBD2
No little in space as well and looking for a solid option for data logging, recording as well as lap times. Didn’t purchase the OEM PDR as I was not that aware of how good it is and really wanted the camera behind my shoulder view. But in any case you may want to check out HPtuner.
07-31-2019, 06:10 PM | #3 |
Drives: 1LE Join Date: Sep 2017
Not sure this is going to help you at all but I use an aim solo DL and I log my brake pressure
08-01-2019, 09:29 AM | #4 |
08-01-2019, 10:23 AM | #5 |
Tried this before with little result: https://www.camaro6.com/forums/showthread.php?t=552784
Lemme know if you find anything out!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
