Old 06-14-2019, 06:19 PM   #1
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Fixing an oxidized clear hood
What would/can you use to remove oxidation from a clear/smoke abs plastic? Would the same method for headlights work?
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 06-14-2019, 06:27 PM   #2
KirkH
I would start with a compound and a foam pad before I got into wet sanding like on headlights.
Old 06-14-2019, 06:46 PM   #3
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Already tried. Didn’t work
Old 06-14-2019, 07:02 PM   #4
KirkH
If you are going to wet sand, start with a small test spot.
400 grit>1000 grit>2000 grit>3000 grit
Then compound and orange pad. Followed by polish and a white pad.
Old 06-14-2019, 08:18 PM   #5
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Yeah those were my thoughts. Thanks
Old 07-10-2019, 02:53 PM   #6
EJR8402
EJR8402's Avatar
Drives: 2019 Red Hot 1SS "Scarlett"
Were you using a DA? If so, what was the abrasiveness of the pad? (cutting, polishing, etc.?)
EJR8402 is offline   Reply With Quote
Old 07-10-2019, 03:05 PM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
It requires a good level of experience/skill, but this is what a rotary was made for; with a hybrid foam/wool pad. I use a flex 3403.
Old 07-10-2019, 03:17 PM   #8
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I have every machine, pads and product known to man if you want to drive up to Weston and you and I can take care of it!!
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
