07-12-2019, 06:54 PM | #15 | |
Drives: 2017 SS 1LE Join Date: Oct 2015
07-12-2019, 07:46 PM | #16 |
Drives: 911SC Join Date: Aug 2018
07-12-2019, 10:11 PM | #17 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
07-13-2019, 01:31 AM | #18 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Hi KJ, Been a while. I've come a long way from the GLHS and RX7s.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
07-13-2019, 01:51 AM | #19 |
Yes, They seen to have more sidewall flex. Last weekend was my first outing on them. It was a totally new setup so I wasn't sure what to expect.
07-13-2019, 07:03 AM | #20 |
Drives: 2016 2SS 6MT Join Date: Nov 2016
Are you using the same lug nut as from your Stock wheels? I am having my wheels mounted and firestone called me wondering if the stock Lug nuts will fit, that it seems like it might be tight. I didnt know the answer and assumed the same lugs from stock wheels would work.
07-14-2019, 07:12 AM | #21 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2017
I would like to have these wheels in 19" in stock offset... But the tire choice in 285/35 and 305/35 is so limited, i Will wait. I had these wheel on my E90 M3, for the price they are great !
07-14-2019, 10:26 AM | #22 |
Drives: 2017 SS 50th Join Date: Jun 2019
I think the recommended tire size is 285/35 and 305/30. There are a lot more choices at 305/30.
07-14-2019, 03:32 PM | #23 | |
07-16-2019, 10:56 AM | #24 | |
I am hearing some clicking sound (like a geiger counter sound almost) from what seems like the front of the car when driving. Is that something specific to these tires being new? (RE71R) I am fairly certain nothing is rubbing. Size is 285-35-19 Front (10 inch), 305-30-19 (11 inch) with alignment spec off of Camaro Track Prep guidelines. Also have aFe Control sway bars and springs. |
07-16-2019, 04:43 PM | #25 | |
Drives: 2018 2SS 1LE Join Date: Jul 2018
I can't feel a difference on the street in regards to steering response and I haven' had a chance to take it to a road course yet . I'm hoping to see a difference in lap times. Almost 40lbs less of rotational mass and an effectively lower gear ratio due of the smaller diameter setup should make some sort of noticeable affect on lap times. Of course that could mean squat if these 888R tires don't perform as well as the factory SC3. |
07-17-2019, 04:02 PM | #26 | |
Drives: 2017 Camaro ZL1 Join Date: Aug 2018
'17 Camaro ZL1 M6
