Old 06-29-2020, 10:55 AM   #1
SONiC MOjO
Drives: 2018 Zl1 A10
Boostane worth it?
I have a ‘18 ZL1 and have had a couple people mention
Boostane is good and I should try it. I’m stuck with 91 Octane where I live
And trying to get to that 93-95 octane level. It seems legit, but is it snake oil?
Should be able to get three tanks out of one bottle.
Anyone ever use it? Good, bad. . ?
SONiC MOjO is offline   Reply With Quote
Old 06-29-2020, 11:06 AM   #2
RyanR623
Drives: SS A8, NPP, Red Hot
It's one of the only ones that actually increase octane. No sunocos around you? Sunoco around here has 87, 89, 91 and 93
RyanR623 is offline   Reply With Quote
Old 06-29-2020, 11:09 AM   #3
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I have been running it on my 2017 ZL1 build all this year as a safety net (never know when you might get a bad tank of gas). We were running ~ 95 octane on the dyno early this year and picked up a bunch of whp (double digit). Right now I run around 97-98 just as a cheap safety net for knock/detonation.
Won't hurt to run it on a stock car not sure of any realized gains on 93, likely minimal. Going from 91 to 93+ in your case would likely show #s on the dyno but nothing you'd feel with a butt dyno.
Old 06-29-2020, 11:09 AM   #4
IneedAZ
IneedAZ's Avatar
I use it all the time. I dont trust the pump gas to always give me a good fill. I have a 5 gal drum. I usually put 8 oz in at a time.
Old 06-29-2020, 11:12 AM   #5
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
I use Race Gas brand race fuel concentrate. It may be easier to use than Boostane as it's available in 2 different sizes the smaller of which treats 8 gallons of 91 and the larger of which treats 16 gallons of 91. No measuring, just dump the can in. I get it thru Summit.
Old 06-29-2020, 11:14 AM   #6
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Expensive peace of mind on a stock set up that 1 you're not experiencing detonation and 2 that you're getting full available power.
Old 06-29-2020, 11:19 AM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Also a good brand and was what I was initially using. The Boostane comes in more concentrated forms. I use a R/C fuel bottle to fill mine on demand based on the amount filled at the pump.
Old 06-29-2020, 11:24 AM   #8
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
this is the same as TORCO right? Have any of you boostane guys ever used torco if so which one do you like the best?
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 06-29-2020, 11:26 AM   #9
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Just as an FYI, Race Gas now has a more concentrated formula, Race Gas Ultra, available for bigger builds. I just like the ease of not having to measure and transfer etc...
Old 06-29-2020, 11:31 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Just be cautious about emissions parts, if you have any on the car. I've read the ingredients, that actually work to stave-off detonation, can/will kill cats' and such. If you don't have them, then it's probably no problem. I think you might have to change plugs more often, too, but just know what you could be getting into.
'20 ZL1 Black "Fury"
Old 06-29-2020, 11:42 AM   #11
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
They are not the same, I've seen Boostane showing their product is superior in some examples to Torco: https://boostane.com/boostane-vs-torco-suspension-test/
Old 06-29-2020, 11:44 AM   #12
IneedAZ
IneedAZ's Avatar
I have tried them all over the years. Not sure if it is only marketing, but when you read what they claim with Boostane, it made me stay with it. I wait for their sales and buy the 5gal drum. I have one of the 32oz cans i think it is that i fill from the drum. The last one i bought was 20% off with free shipping. Think it came out to ~8 per can if you were to break it down.
Old 06-29-2020, 11:44 AM   #13
95 imp
Dumb Ass Deluxe
Seriously doubting that stuff does much good at such a low volume, unless it has lead (which it doesn't).
You'd need 3 gallons of 117 octane fuel (xylene) to bring 15 gal of 91 up to 95 octane
If there were such a thing as an unleaded 129 octane additive, you'd need 1 gal to bring 15 gal up to 93 octane.
Old 06-29-2020, 12:03 PM   #14
SONiC MOjO
Ok, Thanks for the info guys
