Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > ZL1 Parts
Old 01-02-2019, 11:40 AM   #1
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Talking Elite Engineering Catch Can | 2017-19 ZL1 | JDP Motorsports
Hey Camaro6!
JDP Motorsports is proud to offer the Elite Engineering Catch Can for the 6th Gen ZL1 Camaro! We have been working closely with Elite Engineering for more then 10 years now and we are more than satisfied with their service and products. We're offering the Elite Engineering PCV Oil Catch Cans as we feel they are the highest quality piece offered on the market. We install these on nearly all of the cars we work on here at JDP.
Elite Engineering 2nd Gen Catch Can (E21010LT4B)
Elite Engineering 2nd gen catch can features the same 3-chamber design that made the Elite catch can so popular and functional, but has a larger volume. Specifically designed for forced induction, turbo or supercharged engines.
PURPOSE OF YOUR STOCK PCV SYSTEM
The PCV (Positive Crankcase Ventilation) system is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. The PCV system routes crankcase fumes into the intake manifold where they can burned to eliminate harmful emissions into the atmosphere. The PCV valve controls the amount of crankcase flow volume depending on the engine's load. With large throttle openings (high engine loads), the more blow-by gases are produced, and the more the PCV system flows oil vapor in to the intake manifold. The PCV valve also functions as a check valve to prevent intake manifold flow from reversing back into the crankcase when there is a backfire, or during periods of high manifold pressure (boost) during forced induction by turbocharger or supercharger.
NEGATIVE EFFECTS OF YOUR STOCK PCV SYSTEM
Many Corvette owners with LSX engines can testify to the amount of oil residue that can accumulate inside the intake manifold, throttle body, intake track and even the air filter during aggressive driving conditions. There are various negative effects when excess oil vapor contaminates the intake system from the stock PCV system - such as -
- Throttle body and/or MAFS (Mass Air Flow Sensor) malfunction or failure
- Air filter, intercooler (if equipped) and intake ducting contamination if oil pools and run back out the intake system after engine shutdown
- Reduced octane of the air/fuel mixture, which can cause detonation and the ECM (Engine Control Module) to retard timing, thereby reducing engine power
- Excessive carbon build-up on valves, piston crowns, combustion chambers and spark plugs. This also increases the chance of detonation and power loss
- Increased emissions & possible contamination of catalytic converters and oxygen sensors
ULTIMATE FUNCTION
Elite Engineering's PCV Oil Catch Can has a unique 3-chamber design to effectively separate oil from the crankcase vapors, thereby eliminating all negative effects of excessive intake system oil contamination. Oil vapor from the crankcase enters the 1st - Inlet/Filtration chamber where it is slowed down and caught in the stainless steel mesh, it then moves onto the 2nd - Transition/Diffusion chamber. The Diffusion chamber has a very specific set of holes to remove the oil and only let clean air vapor pass. Lastly, the vapor passes into the 3rd - Exit Chamber before it exits the Catch Can.
PREMIUM CONSTRUCTION
The Elite Engineering PCV Oil Catch Can is constructed of the finest materials inside and out. High performance car owners insist on the best products that offer unsurpassed function as well as impressive visual enhancement. The Elite Catch Can does both! Their exclusive design incorporates optimum function and the finest materials, construction and finish for maximum dependability.
Built from billet 6061-T6 aluminum alloy, and then anodized in a variety of colors for a striking look. The internal condensing screen is stainless steel encased inside an aluminum alloy housing designed for low flow restriction. The housing can be disassembled for screen inspection, cleaning or replacement if needed. The inlet and outlet hose fittings are brass, and threaded into the body and sealed with Teflon tape. Supplied hoses are fuel and oil vapor compatible (SAE 30R7 rated). The bottom catch can reservoir screws onto the top of the unit, and is sealed with a built in O-ring. Inspection and cleaning is easy by simply removing the bottom of the unit without disturbing the mounting system or hoses. In keeping with their high quality standards, all supplied mounting hardware and screws are stainless steel. The supplied custom machined bracket is aluminum, and is attached to your specific vehicle with the hardware supplied.
PRODUCT FEATURES:
- Catch can assembly beautifully anodized in BLACK, complete with 3/8" barbed inlet/outlet hose fittings
- Custom machined mounting bracket to fit your specific vehicle and application
- All stainless steel mounting hardware
- 3/8" ID fuel and oil vapor compatible hose
- PCV adapter hardware
- Black zinc plated hose clamps
- Upgraded lines available
- Free Shipping to the Lower 48!
- Made in the USA!
ADDED BENEFITS:
- Elite's 3-chamber design WITH larger 3rd stage
- Available with: 1 or 2 exit ports
- Available with integrated EXIT check valves **
- 30% more volume than Elite's standard catch can
- Can be fully disassembled for easy cleaning or inspection
- Available in anodized black finish
- Elite's check valves are integrated internally to their EXIT hose barb fittings; you can choose to have 1 or 2 EXIT check valves or standard free-flowing hose barb fittings
MSRP: $274.55
Sales Price: $269.50
WE INSTALL PARTS!!
If you are looking to have work performed or have one of our packages installed on your vehicle, we have a facility in Sandy, Utah where we perform everything from bolt-on installations, Dyno testing/tuning and complete race car builds. Our install shop fills up fast, so please call us to set up an appointment. Our expert staff is eager to assist you. We appreciate your interest in our products and have a great day!
Cheers,
Kayla L.
801.545.4215
Sales@jdpmotorsports.com
JDP Sales is offline   Reply With Quote
Old 01-02-2019, 11:54 AM   #2
ToeKnee Sea
Drives: 2018 Camaro SS 1LE
Hi JDP - been on your website a few times since November. Not clear from the website that you still sell parts. Looks like you are only a performance shop now. Where are all the items you have for sale?
thanks!
ToeKnee Sea is offline   Reply With Quote
Old 01-02-2019, 05:46 PM   #3
JDP Sales
JDP Sales's Avatar
thanks!
We have changed the lay out of our new website. On the home page you will see options for our packages but at the top right hand corner you will see on option for our store. That is where you will find all of our items for sale. Please let us know if you have any other questions!
Cheers,
Kayla L.
801.545.4215
Old 01-02-2019, 05:51 PM   #4
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Drives: 2019 Riverside blue ZL1 Camaro
Do you have the E-2x in stock?
http://www.eliteengineeringusa.com/e2-x-catch-cans/
2ltrgsr is offline   Reply With Quote
Old 01-03-2019, 09:42 AM   #5
JDP Sales
JDP Sales's Avatar
Originally Posted by 2ltrgsr View Post
Always in stock and ready to ship!
Feel free to call, PM or email us at any time to place your order .
Cheers,
Kayla L.
801.545.4215
Old 01-03-2019, 11:59 AM   #6
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Cheers,
Kayla L.
801.545.4215
I only saw the regular E-2 catch can on your site... do you have the link for the E-2X
Old 01-30-2019, 10:09 AM   #7
JDP Sales
JDP Sales's Avatar
Give us a call at anytime if you have questions about our products .
Cheers,
Kayla L.
801.545.4215
catch can, elite catch can, elite e2, jdp, jdp motorsports
