01-16-2013, 08:06 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Jan 2013
New Owner few Issues (I have searched the forums)
Hey Guys, recently picked up a 2011 2SS/RS.
Car drives great, but there are some issues that i have noticed. I did search each individual one, but i could not find a direct response. Hoping you guys could help here. (made an appt to send the car in to chevrolet already). 1. Clutch Engagement Point is very high. - I read online about this and apparently its normal, but mine is at least over 3/4 from the floor. Not new to a stick. 2. Whirring Noise from engine when at low revvs or idle. - The car sat at the dealer since september before i picked it up this week. When i first got it, the whirring sound seemed like it was coming from a worn fan belt or alternator. I think it might be the alternator due to the following other issues. --Interior light dims when hazard lights are on.(When the hazards flash, the interior light dims, when the hazards go off, the interior light brightens) --Engine turn over sounds weak and slow. (Not sure about this, but the engine sounds weak at turn over, and the lights all dim as well at turn over). ALTERNATOR? Thanks again guys! |
01-16-2013, 08:41 PM | #2 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
I'd have them check the alternator and battery to make sure they are charging properly.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
01-16-2013, 08:51 PM | #3 |
Stroked and blown
I miss the stock clutch. It is set very high. 20 percent down is usually all it took. Clutch sounds normal. Other stuff not so much
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
01-16-2013, 09:31 PM | #4 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Is the car used? If so, I wonder if the previous owner installed an under drive pulley. It will cause the alternator to turn slower so maybe the battery isn't getting a full charge. I don't know if a slower rotating alternator would cause a whine though! Sounds like the dealer needs to check the charging system! Good luck!
01-17-2013, 12:48 AM | #5 |
COTW 5/27/13
Clutch is normal. Not sure about whirring noise but the dimming of the lights with hazards is also normal as mine has done it from day one. The cars are also slow to turn over, my 93 honda accord would turn over and start faster then these cars.
All in all I would only be concerned with the noise, if you can find someone local and see if theres does it also.
622RWHP/512FTLBS on 91 octane 2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned My build thread |
01-17-2013, 12:56 AM | #6 |
Drives: pleather and Chiclets Join Date: Mar 2012
strange, i dont have that lighting issue nor a whine nor a weak engine turn over. i do have a l99 dont know if that makes a difference. i would have it checked out. i have driven in camaros with underdrive pulleys that did not experience any of these probs either.
01-17-2013, 06:32 AM | #7 |
Drives: Yes Join Date: Dec 2012
# 1 normal
# 2 might be pwr steering pump making noise. # 3 and # 4 bad cell in battery! Would be my guess. Take and have battery check.. |
01-17-2013, 07:00 AM | #8 |
Drives: camaro Join Date: Jan 2013
yeah,agere, It is set very high. 20 percent down is usually all it took. Clutch sounds normal. Other stuff not so much
01-17-2013, 08:47 AM | #9 | |
Drives: GM Vehicles Join Date: Jun 2010
Please let us know what you decide to do. Brandon Chevrolet Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
01-17-2013, 04:19 PM | #10 |
Thanks for all the feedback!
Sent my car back to the dealership i bought it from, and they lubricated some parts and its alot quieter now. No more whirring noise. A battery check was done too, and all electricals are supposed to be fine. That said the car does have a rattling noise now coming from the back, sounds like the exhaust. But i will wait till i send it on saturday to a chevy dealer to check that out. Thanks again. |
01-18-2013, 10:31 AM | #11 | |
This is great to hear that the whirring noise went away. Let us know if you have any comments or questions at your convenience. Brandon Chevrolet Customer Service
01-18-2013, 11:27 AM | #12 |
Drives: 2ss Join Date: Apr 2012
Just be glad you're not smelling burnt oil thru the ac vents! please post if you do though as i am researching if this issue has been addressed in the later models. thanks and good luck with that rattling sound, hope they get it fixed for you.
