Long hauler
Rear knuckle bushing part number or availability?
Both my rear knuckle bushings have their boots damaged and I'm trying to see if I can get the bushings separate from the knuckle.
Looking to see if I can find a place to buy #3 part or for a part number. I'm hoping it can be found without buying two new knuckles. I do see BMR has some bearing kits which I believe their 3rd one would work for me as well. I'm not 100% sure on that though if it's the same piece I need to replace or not, if I decide to go with the BMR bearing kit though I'll contact them and confirm. Though at that point I feel like buying 2 new knuckles would be similar in price. I'm sitting at 97k miles so maybe new knuckles would be better for long term as the other bushings may give problems or maybe I'm thinking too much into it. Any advice or help would be appreciated.
Car Journal
Overkill Tune - K&N CAI - Ported 80mm Throttle Body - Ported Intake Manifold - 4 Piston Brembos - FE3 Shocks - Eibach Pro Springs - BMR Lower Control Arms - MeganRacing Toe Arms Happiness: Infinite. |
![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Is that the bushing in the toe rod? I have yet to see them sold separately anywhere. I know the #2 bushings are available as spherical bearings, but #3 I was planning on eventually just replacing the toe rod as an entire piece.
I know this doesn't help with getting just a bushing, I'm curious what you end up going with, I've slowly been upgrading all my suspension. |
#3 | |
Long hauler
Here’s 2 pics that hopefully clear up the bushing in question The toe arm screws into the knuckle entirety, you can just replace with a aftermarket toe arm. BMR probably the most popular, I replaced mine to Megan racing (blue) arms since they were cheap at a local deal and I needed to replace one anyways
Car Journal
![]() Drives: Camaro 1ss Join Date: Nov 2019
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
spl parts ftw !
#6 | |
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2009
#7 | |
#8 | |
Long hauler
I’ll PM you, if there’s a way to get just a pair of the bushings that I need to replace then I’ll probably get those and have a shop install them
Car Journal
#9 | |
Tags |
bushing, knuckle, replacement |
Thread Tools | |
