Old 01-23-2021, 10:39 AM   #1
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Upgrade for the Track
If you were going to road race a ZL1, what suspension changes would you make while keeping the adjustable mag ride to give you the absolute best track handling and track time.
Bangkok_ZL1 is offline   Reply With Quote
Old 01-23-2021, 10:52 AM   #2
PROMETHEUS
PROMETHEUS's Avatar
BMR upgrades to the rear and the lockout kit.
Old 01-23-2021, 10:55 AM   #3
racer01
Drives: 19' ZL1
100% Rear toe rods (SPL or BMR) and 1LE solid cradle bushing or lockout. Thats it.
Stock rear toe gets knocked out every dang track day for me. PITA
racer01 is offline   Reply With Quote
Old 01-23-2021, 11:16 AM   #4
gtfoxy
Drives: '21 Wild Cherry ZL1
What can be an expected improvement of the 3r’s over the standard 3’s.
Also, IIRC, he has Continentals on his.
Old 01-23-2021, 12:13 PM   #5
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Do ZL1 and ZL1 1LE have the same OEM toe rods?
ninetres is offline   Reply With Quote
Old 01-23-2021, 03:14 PM   #6
racer01
Drives: 19' ZL1
3R is probably good for close to 1 sec improvement for every mile of track I'd say (of course depending on the track). Quite a bit stickier and last maybe 25%-35% as long as the 3's. Problem is more stick = more suspension lean, so need stiffer setup and more camber to really use the tire properly. I think regular 3's are a damn good match for a stock street/track ZL1 personally with track alignment settings.
Old 01-23-2021, 05:21 PM   #7
Tay
Drives: 1985 Oldsmobuick
DSC Tractive coilovers and controller. *you would be ditching the mag ride but it does keep it adjustable:
https://www.dscsport.com/product/cam...-coilover-kit/
Full SPL catalogue:
https://www.splparts.com/camaro-6th-gen-2016/
Hotchkis front bar and BMR rear bar with SPL end links
https://www.camaro6.com/forums/showthread.php?t=563149
Tay is offline   Reply With Quote
Old 01-23-2021, 07:35 PM   #8
20Bluezl1
I bought SPL parts and still have more on the list. I also have the GMPP bushing kit
Old 01-23-2021, 07:38 PM   #9
20Bluezl1
Full SPL catalogue:
I have read about the Tractive Coilovers and controller and tbey seen like it will outperform the DSSV and still feel good on the street. Maybe in the near future I'll upgrade.
Old 01-23-2021, 08:43 PM   #10
dbs1
Drives: 2017 ZL1
I'd start with time on track. Most folks will not get 7 out of 10 the way the car is.
1. Seat time
2. Lightweight wheels & track tires
3. Track pads
4. More seat time
dbs1 is offline   Reply With Quote
Old 01-23-2021, 08:45 PM   #11
gtfoxy
I was under the impression brake fluid was heavily recommended..
Old 01-24-2021, 05:15 PM   #12
Apexslayer
Drives: Zl1 1le
Seat time
Brake fluid - Castrol SRF or Motul
Camber
Seat time
Seat time
Seat time
Apexslayer is offline   Reply With Quote
Old 01-25-2021, 09:54 PM   #13
mblum
Drives: 2017 ZL1 Camaro
Originally Posted by Apexslayer View Post
Seat time
Camber
Seat time
Seat time
Seat time
I 100% agree.
Id put heavy emphasis on the track alignment, it make a very noticeable difference. Track time and more track time. Stock tires work very well.
The only mod I have done is the BMR cradle lock out kit. I definitely could feel the difference on track
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle
mblum is offline   Reply With Quote
Old 01-26-2021, 03:12 AM   #14
Bangkok_ZL1
ZL1 Believer
Continentals??? Not for long. I'm going back to my Michelin PSC2's on the rear when these wear out (when I had my 7, 15 years ago, it was PSC's on the rear (and PS on the front) and loved the grip). I will have an extra set of racing wheels that I'll bring in my trailer. I learned about this awesome Formula 1 certified track we have here, brand new Chang Circuit, about 4 hours from my "current" house. I might have to buy a retirement home there if I really start liking the track. So it will be PSC2 or the Toyos all the way around, whatever people believe is gripping the most for the best lap times...... and I'm going to buy an after market suspension set up that will let the alignment be adjusted once and it will stay. Hopefully, I'll be able to save the 2 alignment settings (a fine line marks the spots, Touring and Track) and then adjust them on my own back at my house. I'm also buying my own lift in a few weeks. Life will be good once I change treads though. These Contis are already heat cycled and I can easily lose traction in 5th gear with about 50% throttle, even on cement they're starting to get squirrelly in 3rd. On the other hand, it is too much fun in Sport mode with the safeties off, LOL. Slid'in the Bit@h everywhere. I love it.... Thailand is a great place to drive.... the only rule is don't wreck.
