Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 01-16-2021, 11:39 PM   #1
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
MSD whistle
Installed my ported MSD and 95mm TB. Thing f**** pulls hard. But it makes some whistling sound like a deflating balloon at low speeds light throttle? Wonder if itís the GM CAI without that lame diverter plate now that the LT5 Tb is in. Idk. Help me please.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, GM CAI, TSB 1 7/8Ē headers, Pray ported MSD, 95mm TB
BruceWayne1LE is offline   Reply With Quote
Old 01-17-2021, 07:40 AM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Check your gasket fitting and turn the gasket facing the other way. Tighten TB to 89 lbs.
2019 Camaro 1SS 1LE
LT2 Intake Manifold (ported)95mm TB
MRC HUD Mighty Mouse Catch Can, GM CAI
Secondary Cat Delete with resonators
Flowmaster Super 10ís & 4 inch tips
SJM Line Lock & Hurst Pistol Grip
Special Sauce (NOS)
BlackbeastSS2 is offline   Reply With Quote
Old 01-17-2021, 09:50 AM   #3
BruceWayne1LE
Iíll give that a try. Better than removing the manifold. I figured those gaskets arenít handed.
Old 01-17-2021, 10:04 AM   #4
BruceWayne1LE
I also re-used the stock TB bolts. Didn’t back out the brass inserts. But now I’m afraid maybe punctured the manifold? Idk just spitballing.
Old 01-17-2021, 10:53 AM   #5
Puddin
You may have punctured the manifold because MSD gives you new bolts and washers to use that way you don't puncture it when installing the throttle body.
Old 01-17-2021, 11:10 AM   #6
BruceWayne1LE
Yea I didnít get them as I bought mine used. But the bottom bolts go all the way through. The top 2 are the 2 that are encased. But I imagine it would back out the brass fitting before puncturing. Iíll take a look. Nothing a little epoxy canít fix
Old 01-17-2021, 11:36 AM   #7
BlackbeastSS2
If the bolts go to far in just put some washers on to act like a spacer. RTV is your best friend after this.
2019 Camaro 1SS 1LE
Special Sauce (NOS)
Old 01-17-2021, 01:15 PM   #8
BruceWayne1LE
I checked the hole depth with a micrometer and the stock bolts a just shy of the bolt hole depth of the msd. Just to be safe I bought some shorter M6 bolts. Checked the backside of the casting and found no signs of puncture. Car idles fine and pulls fine no codes. Starting to thin the 95mm Tb makes some noise stock? Maybe the blade screws are making this sound idk. Gonna put my ported sticker on and see what’s up. Maybe some RTV on the snout face? I followed the torque specs to a T so idk what it is. It’s just annoying.
I did notice that the brake line booster hose doesn’t seat all the way like it does on the stock unit. Brake pedal is firm so no issues there.
Old 01-17-2021, 01:16 PM   #9
BruceWayne1LE
Did you use RTV on the snout face?
Old 01-17-2021, 01:46 PM   #10
BlackbeastSS2
I have done my test fits and I am back to stock manifold because it’s going to get heads and cam soon. Once the that’s done then I am going to use RTV to sealer up mainly because of the porting. No more O ring gasket. Paper and RTV should be 100% fine. Back to stock manifold because I do want to base line my car because of current CAI, secondary cat delete, and 3 inch custom rear axle stainless steel with FM super 10’s mufflers then I can see the true gains of the mods with the LT2/95mm/cam/heads and NOS.
2019 Camaro 1SS 1LE
Special Sauce (NOS)
Old 01-17-2021, 01:59 PM   #11
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2016 2SS Convertible
I wouldn't bother trying the GM plate, it was designed for the LT1 and would probably cause problems if installed on anything but factory stuff.
If you bought the MSD used, did you replace the gasket with a new one? The OEM gasket - which looks pretty similar to the MSD - is supposed to be replaced whenever you remove the throttle body. I would be that is your issue. Just get a new MSD gasket.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav.
SomeGeoffGuy is offline   Reply With Quote
Old 01-17-2021, 02:00 PM   #12
BruceWayne1LE
Hmmm well the paper gasket is gonna be solid for sure. I may try that and if this kills the whistle I’ll know the problem. If not I’m gonna have a f’n mental breakdown. Sounds like a micro bypass valve. Since my car has no turbo it’s not a cool noise
Old 01-17-2021, 02:06 PM   #13
BruceWayne1LE
-Geoff
I have all new gaskets.. hmm
Old 01-17-2021, 02:14 PM   #14
BruceWayne1LE
What makes it weird is that it idles totally fine. No codes nothing. I figure if it was a leak it would either idle rough or throw a code. It would be pulling air after the MAF
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
