Old 11-02-2020, 10:08 AM   #1
juice3
juice3's Avatar
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V
JRE Built ZL1 1LE Goes 1:14 at Summit Point
Get with JRE on the build - This monster kicks arse and takes names.
All the 2650R heating woes are behind me and I finally got to put some laps down!
NASA Mid-Atlantic TT1 Championship - 6th Gen Track Record
https://youtu.be/xuLYJ_rCsng
juice3 is offline   Reply With Quote
Old 11-02-2020, 10:54 AM   #2
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
what did you do to solve the heat issues?
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 11-02-2020, 11:31 AM   #3
juice3
juice3's Avatar
Combination of Header Shield on the Headers, CAM (more fueling), Less Boost, Heads by Katech, C&R Radiator, Coated everything we could.
I got more Power Through Effenciency.
on 4.5# less boost it made like 70ish more whp than the last time up to JRE.
I could go longer then the Hoosier A7s would stay grippy.
Old 11-02-2020, 11:57 AM   #4
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Congrats! Awesome build, I saw a video from your car on JRE's Facebook page.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 11-02-2020, 12:00 PM   #5
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Was the initial build, that was running hot, from JRE?
Old 11-02-2020, 01:05 PM   #6
Checkmate1
Drives: Garnet Red / ZL1 1LE
Wait, all that effort + money + Hoosiers + Auto and only 2-3 seconds faster than a stock Manual ZL1 1LE driven by David Kramar?
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 11-02-2020, 01:21 PM   #7
juice3
juice3's Avatar
It was, I asked for a lot of whp from JRE. The heat was a byproduct of that request.
Many across the country trying to run higher than stock boost and do road course stuff were having problems with heat on sustained laps. There will be a different package reccomendation for JRE customers that want to road course, especially the A10 owners.
Old 11-02-2020, 01:22 PM   #8
juice3
juice3's Avatar
David isn't 100% stock, and yes on a very short course finding 2-3 seconds does start to cost big bucks.
My car has a 12/13 in it. You will spend booku $ going faster.
Old 11-02-2020, 02:45 PM   #9
cirpower
Drives: Camaro ZL1
Nice driving and great car. Thanks for sharing your insights with us.
Are you running A7s and if so, which dimensions?
cheers
cirpower
cirpower is offline   Reply With Quote
Old 11-02-2020, 03:05 PM   #10
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
2-3 seconds on that track is 4-6+ seconds on most others, it's a big diff. Great lap!
SFV1LE is offline   Reply With Quote
Old 11-02-2020, 03:25 PM   #11
juice3
juice3's Avatar
cheers
cirpower
345/315 A7s on Forgeline 19s
Old 11-02-2020, 04:28 PM   #12
cirpower
Drives: Camaro ZL1
Thank you, that is 345-30-19 and 315-30-19?
How much camber? Any rubbing?
cheers
cirpower
Old 11-02-2020, 06:36 PM   #13
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Wow! Very nice!
