Old 11-09-2020, 12:49 PM   #43
XNZT38
XNZT38's Avatar
Drives: 2020 Camaro 2SS Coupe
Originally Posted by 1hprush View Post
Thanks to forum member Glen e for the install suggestion. Here are some pics that I took today during my install.
Remove the cover that's next to the fuse box. Push down on the tabs and lift. Attach your (+) feed to one of the empty post, I used the 4th post, and attached the (-) feed to the negative bolt, and then snap the cover back in place. I ran the cord through the hood latch and out through the front grill. Enjoy!
What Battery Tender do you recommend?
1100 - 1/30/20 | 2000 - 2/3/20
3000 - 2/04/20 TPW 3/02/20
3100 - 2/08/20 | 3300 - 2/13/20
3400 - 2/17/20 | 3800 - 3/2/20
4300 - 3/6/20 | 4200 - 3/9/20
5000 - 3/9/20 | 6000 - 3/10/20
XNZT38 is offline   Reply With Quote
Old 11-10-2020, 07:35 AM   #44
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Battery Tender Plus
Current: 2018 ZL1 ZLE
Memories:
2017 50th Anniversary Camaro Convertible (Sold)
2003 Dodge Viper (Sold)
2005 Lingenfelter Corvette (Sold)
2004 Mazda RX-8 (Sold)
1hprush is offline   Reply With Quote
Old 11-10-2020, 08:10 AM   #45
Invertalon
Drives: 2021 2SS
CTEK, for sure. After all my research, they are the 'standard' as far as battery tender quality go (they also make the "GM/Camaro Tender, FYI).
CTEK MXS 5.0 - https://www.amazon.com/CTEK-40-206-5.../dp/B00CD44RQO
Used it yesterday on mine, just plugged into the terminals under the hood. Not storing the car, but was curious what type of charging/topping off it would do to the battery, which is only 3 months old and 1,000 miles on the ODO.
It still did a few hours of bulk charging (up to 80%) and then a few more hours at the lower current charge up to 100% before going into the 'pulse/hold' stage. Surprised it needed as much time as it did, honestly!
Great device just to have, even if not storing your car long term. Use it on our Mazda 3 beater every few weeks which is driven maybe once or twice a week to take the dog to the park and back (shorter trip). Relatively inexpensive maintenance item.
Invertalon is offline   Reply With Quote
Old 11-10-2020, 08:21 AM   #46
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Battery Minder 1500 which include the de-sulfurator mode.....
Old 11-10-2020, 09:05 AM   #47
ember1205
Hot Camaro
ember1205's Avatar
I have three Schneider tenders and a Battery Tender Junior that all work just fine. The important thing is to research to ensure that they are able to correctly charge and maintain the AGM batteries that are in our cars (most seem to be able to do this). The smaller ones will simply charge more slowly. I used the Junior on an older Accord that had been sitting. With it's 3/4A output, it took close to two days to get the battery fully charged because the car had been sitting for more than a couple of months with zero use in colder weather.
Old 01-26-2021, 11:47 AM   #48
MoreSpeed
MoreSpeed's Avatar
I use this as well. I also bought the 12 volt battery adapter so I just plug it into the cigarette lighter. Makes it impossible to forget it is plugged in and try to drive away. I like to low voltage aspect of this unit as a tender. It is not meant to quickly jump start a dead battery.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 01-26-2021, 12:17 PM   #49
joekd
Drives: 2018 Camaro SS vert
I did that on my last car but the Camaro lighter plug doesnt stay hot with ignition off so I connected leads directly to the battery
joekd is offline   Reply With Quote
Old 01-27-2021, 12:04 PM   #50
splatrd
splatrd's Avatar
SAE Socket
I always add tender to my vehicles, with several to drive some sit for a while. I found these SAE sockets from the solar panel and RV industry that make for a nice clean install without just leaving a cord hanging. Just be careful about the polarity.
The flange has 4 holes to either screw or zip tie to a grille bar.
http://www.solarseller.com/low_volta...extensions.htm
splatrd is offline   Reply With Quote
Old 01-27-2021, 04:18 PM   #51
GroundhogSS
GroundhogSS's Avatar
Thanks splatrd. Great tip.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 03-15-2021, 09:45 PM   #52
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
What size nuts is the nut required for post #4 on the positive side?
Old 03-15-2021, 10:17 PM   #53
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I installed my tender by the battery and hooked up a plug outlet bottom right rear. You can’t even see it unless you get down and look under the car.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-15-2021, 11:54 PM   #54
Ron2ss
Ron2ss's Avatar
Drives: 2020 2ss vert
Nice install!
Ron2ss is offline   Reply With Quote
Old 03-16-2021, 07:36 AM   #55
ember1205
Hot Camaro
ember1205's Avatar
There are a few folks that posted in this thread that they used #M6.
Old 03-16-2021, 09:26 AM   #56
Wuiquen
Wuiquen's Avatar
Nice .. i would be afraid to forget and drive off with it connected
Sent from my moto g(7) power using Tapatalk
