Old 12-14-2023, 02:58 PM   #1
Nesin
Nesin's Avatar
Drives: 2016 Camaro 2SS MT MRC
MRC Rocking when overtaking
Hi,
I have a 2016 Camaro 2SS V8 MT with MRC.
When downshifting and overtaking, the car starts to shake. The MRC was also recalibrated, this may be a skeptical feeling, but it seems to be better, but not good.
Has anyone had such a problem and how to solve it?
Nesin is offline   Reply With Quote
Old 12-14-2023, 11:42 PM   #2
You or a mechanic needs to check all 4 MRC struts for leaks, unfortunately several members here saw them go bad after 5-6 years. In one case they collapsed completely, leading to an extremely bumpy ride.
Old 12-15-2023, 05:10 AM   #3
Nesin
Nesin's Avatar
Thanks. If there was a shock absorber leak, wouldn't the "MRC service" error be displayed?
Old 12-15-2023, 07:35 AM   #4
Osbornsm
Drives: 2018 SS 1LE
I, too, have this question.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 12-15-2023, 07:43 AM   #5
Sorry guys, I don't know if a code is set in that case. I also feel that it will, but someone who actually had an MRC shock fail should be able to tell us.
Old 12-15-2023, 09:48 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I haven't had a MRC shock leak or go bad but the "service suspension" will come up on on the dash, no computer fault code, if the sensor if any of the wheels becomes disconnected. The ride will be very bumpy and choppy and you'll know that there's a problem. My 23 had become disconnected on the RR and it was as simple as reconnecting the arm on the sensor.
Old 12-15-2023, 01:32 PM   #7
Nesin
Nesin's Avatar
I understand that the cable from the tilt sensor on the swing arm has disconnected and that's where the message on the dashboard comes from?
Old 12-15-2023, 07:37 PM   #8
WhiteMale
On my car it was the arm of the sensor becoming disconnected from the control arm not a cable or wiring.
Old 12-17-2023, 02:31 PM   #9
Nesin
Nesin's Avatar
Ah, I understand now. I need to check if everything is ok. Thank you.
Old 12-19-2023, 03:30 PM   #10
easttxss
easttxss's Avatar
Drives: '16 2SS M6
I had a sticking/notchy front strut and a slightly leaking rear, but the real problem with the rear was a torn lower bushing (causing a clunking noise) that they don't sell replacements for so you have to replace the whole shock. No warning lights or codes were set, just a noisy stiffer than normal ride.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
