Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 04-02-2019, 07:55 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
6th Gen Camaro Cold Air Intakes from SCP! Free Shipping and Lowest Prices!
We've got all the best brands, always with free shipping and the lowest possible prices. We carry K&N, aFe, Mishimoto, Cold Air Inductions and more!
2016-2018 CAMARO MOMENTUM GT PRO DRY S STAGE-2 INTAKE SYSTEM V8-6.2L
Increasing the engine's overall performance is number one on every car guys list. The stock intake system is one of the most restricting parts on your vehicle by limiting the amount of air the engine receives. Replacing the stock cold air intake will add horsepower and torque you can hear and feel. The more air your engine gets, the more power it will produce. aFe's Momentum Series Cold Air Intakes are designed using the most up-to-date engineering tools and techniques to provide you with the perfect blend of power and protection.
2016-2018 6TH GENERATION CAMARO AIRAID DRY INTAKE KIT 251-333
Since the 6th Generation Camaro SS doesn't have enough horsepower already....right? If you are not happy with over 400 horsepower already then it might be worth a second look to upgrade your factory airbox to a high flowing unit like this Airaid Dry Intake Kit. Airaid 251-333 is designed to make maximum power out of your 2016-2018 Camaro. Dyno tests show that this Airaid will give you 10 additional horsepower and 10 lb torque.
2016-2018 CAMARO K&N 63-3094 AIR INTAKE SYSTEM 3.6L V6 F/I - ALL
Cold air intakes make your Camaros horsepower increase for the least amount of pocket change. With cooler and more air this is a great thing for performance.
The K&N AirCharger 63-3094 air intake system replaces the restrictive factory air filter and air intake housing in select Chevrolet Camaro models. K&N air intakes are designed to dramatically reduce air intake restriction as they smooth and straighten air flow. This allows your Camaro’s engine to inhale a larger amount of air than the factory air filter assembly. More air means more usable power and acceleration throughout the engine’s RPM range.
2016-2018 CAMARO SS K&N TYPHOON COLD AIR INTAKE
Get the most our of your Camaro SS with this K&N Typhoon Cold Air Intake kit. Dyno tested to add 18.2HP to a stock 6th Gen Camaro SS. The Camaro SS already performs like crazy, but a little extra HP never hurts!
2016-2018 6TH GENERATION CAMARO SS MOMENTUM GT PRO 5R STAGE-2 INTAKE SYSTEM
Unique One-Piece High-Quality Housing W/ Sight Window:
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air scoop.
2016-2018 CAMARO SS AIRAID COLD AIR INTAKE 250-333
Looking for a little more horsepower from your 6th Gen Camaro SS? If you are like us, you believe you can never have too much horsepower. Good thing Airaid provides such quality cold air intakes for the 2016+ Camaro.
2016-2018 CAMARO 6TH GEN 6.2 COLD AIR INDUCTIONS INC. COLD AIR INTAKE SYSTEM
Maximize your vehicle's performance with a Cold Air Inductions Inc. Air Intake System. Our Systems represent the highest quality in the marketplace due to superior materials and craftsmanship. The systems have insulated airboxes with a removable lid and a filter inspection window. Other features include thermally coated intake tubes to reduce heat soak. All of our performance gains are backed up with accurate and real world dyno testing.
This product is a direct replacement for the OEM air intake system. No modifications required.
2016-2018 6TH GENERATION CAMARO SS K&N AIRCHARGER INTAKE 63-3092
Your 2016-2018 6th Gen Camaro already makes huge horsepower numbers, but this K&N intake will take your Camaro SS to a whole new level. This intake kit will give your 6.2L another 24HP and 18LB!! Those numbers are incredible. A simply bolt in intake and you can really fell the extra power.The K&N 63-3092 AirCharger is designed to reduce air intake restriction and smooth and straighten air flow for your Gen6 Camaro SS. Air is directed through an aerodynamically engineered intake tube into the engine’s throttle body for a guaranteed power gain. The tube accommodates the factory mass air sensor and crank case vent hose.
2016-2018 CAMARO SS 6.2 L MISHIMOTO COLD AIR INTAKE
ADD HORSEPOWER AND SOUND TO YOUR RIDE WITH THE NEW MISHIMOTO PERFORMANCE AIR INTAKE. THIS KIT IS ENGINEERED SPECIFICALLY FOR YOUR CAR AND INCLUDES EVERYTHING NEEDED TO REPLACE THE RESTRICTIVE STOCK AIRBOX. INSTALLATION IS QUICK AND SIMPLE, PERFECT FOR SOME EXTRA PUNCH ON THE STREET OR AUTOCROSS COURSE.
2016-2018 CAMARO K&N BLACKHAWK AIR INTAKE INTAKE SYSTEM
The K&N Blackhawk Induction Air Intake System is a free-flowing, mandrel-bent aluminum tube air intake system that is guaranteed to gain power. It will replace the restrictive factory air filter and air intake housing on 2016-2018 Camaro SS models.
southerncarparts is offline   Reply With Quote
Old 10-08-2019, 10:10 AM   #2
southerncarparts
Old 12-23-2019, 09:21 AM   #3
southerncarparts
Thank you for the orders!
Old 08-29-2022, 03:00 PM   #4
southerncarparts
2016-2019 CAMARO MOMENTUM GT PRO DRY S STAGE-2 INTAKE SYSTEM V8-6.2L
