Old 08-22-2018, 11:40 AM   #1
RDBURNR
RDBURNR's Avatar
Drives: 2016 Camarro 2SS
Reduced Performance Reduce Clutch Use
Had the upgrades in signature line installed recently, now in 3rd, 4th, 5th and even 6th gear I am getting the message "Reduced Performance Reduce Clutch Use" while hard acceleration in 3, 4 and 5 and slight acceleration in 5th and 6th. Can do a 1st gear burnout without tripping it. When it occurs immediate power drop, and returns immediately when letting off the gas. Not sure if clutch is slipping or not.
Any ideas?
______________________________________
2016 2SS
P1SC-1 Procharger
Stage 2 Intercooler w/ Race BOV
ZL1 Fuel Upgrade
LT4 Injectors
Fuel Voltage Booster
AEM Boost and AFR Gauges
Dynatech 1 7/8th Headers
JRE Tuning
RDBURNR is offline   Reply With Quote
Old 08-22-2018, 01:08 PM   #2
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
with a datalog you can see clutch slip. you'll wanna log the motor rpm speed vs trans output speed/wheelspeed and do some math. if it's slipping you will be able to see that in the log.
hitmix300 is offline   Reply With Quote
Old 05-09-2019, 10:42 PM   #3
CamaroSSRS11
Drives: 2017 White SS 1LE
Unhappy
Have you figured out what was wrong? I just did a multi-track weekend and I'm having the same problem. On the autocross, it's fine. When I go onto the road course and drag strip, I get that message after the second lap or so. The check engine light doesn't come on and the car doesn't sound or feel like anything is wrong. It just cuts power at about 5k rpm in those gears. It is very frustrating and my tuner says without a code, it is very hard to narrow down.
CamaroSSRS11 is offline   Reply With Quote
Old 09-22-2020, 02:59 PM   #4
brannon
Drives: 2018 ZL1
Ever figure out what caused that? I am now having the same problem.
brannon is offline   Reply With Quote
