04-13-2016, 10:28 AM | #1 |
RPI Designs 2016 Camaro SS W/ Dual Mode Exh. (NPP) Borla Rear Section Exhaust ATAK
2016 Camaro SS W/ Dual Mode Exh. (NPP) Borla Rear Section Exhaust ATAK #11925
BORLA® ATAK® (Acoustically Tuned Applied Kinetics) technology is designed for high-performance purists who prefer exhaust sound over their stereos. ATAK®-equipped exhaust systems deliver the highest available dB (decibel) levels in the BORLA® street-legal lineup... and unlike inferior brands that lose significant sound quality at higher volumes, ATAK® is tuned like a graphic equalizer to shape and focus sound waves for optimum high-volume output. ATAK® technology is based on specifically-tuned attributes of the internal muffler cores, which are calibrated on a vehicle-by-vehicle basis to deliver the most desirable sound. For more details and to hear the difference, watch our ATAK® videos below for different make and model vehicles. The power of BORLA® Multicore® technology, with the sound of vehicle-specific acoustic tuning! Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gases, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds. Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship. This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used). Application: •2016 Camaro SS 6.2L with Dual Mode Exhaust Item # BO11925 Website Link : http://www.rpidesigns.com/shop/item....-exhaust-atak/ |
10-14-2018, 11:13 AM | #2 |
Thank you for the orders!
09-19-2021, 07:17 AM | #3 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
