03-31-2016, 03:02 PM | #1 |
Drives: 2009 Corvette Z06 Join Date: Aug 2009
Now available from SCP: 2016 Camaro SS Stainless Works Headers
2016 Camaro SS headers featuring port-matched flanges and mandrel-bent primaries and leads. From port-matched flanges to our slip-fit leads, our headers easily align to your existing factory connection point. Our Camaro SS 2016 System includes adapters for both Factory and Performance connections, making it easy to install whether you have the stock exhaust or our Stainless Works Performance Exhaust Systems. Our leads include either full valve support or a valve delete plate that allows you to mount the electric motor and alleviate any AFM engine codes on the dash. Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers. Features: - 3" diameter system - 3" port-matched flanges - Support For Dual-Mode Performance Upgrade Including Functioning Valve - 304 stainless steel construction - TIG welded for strength - Mandrel bent (no buckling) for optimal flow - Design and Made in Chagrin Falls, Ohio, USA Performance and Sound Proudly Made in the USA Innovative Design: We take our years of experience, and inject that knowledge into creating performance systems that maximize horsepower, torque and sound. Each system is designed for the specific vehicle with distinct features to get the most performance possible along with great fitment. Solid Construction: Made to withstand grueling engine conditions, Stainless Works exhaust and headers are fabricated from 304 stainless steel, which not only resist corrosion, but is stronger than its aluminum or steel counterparts. Increased Power: Factory manifolds can be restrictive and hold back the true potential of your ride. Stainless Works' systems unlock the power of your engine. Our long tube, free- flowing design reduces back pressure, and will bring new found power that you can feel and hear. Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship. Install-Ready: We want to make sure installation goes as smoothly as possible, that's why Stainless Works systems come Install-Ready. Whether clamps, O2 extensions, bolts or RTV silicone, our headers and exhausts come with all necessary accessories to make installation as smooth as possible. Make It Your Own With Custom Options Choose Your Connection: Stainless Works Camaro systems come in two configurations: Factory Connect and Performance Connect. Factory Connect allows our headers or exhaust to easily bolt to the factory exhaust or manifolds respectively. They connect at the factory location which is necked-down to accommodate fitment. Performance Connect is designed to take advantage of performance gains not possible with the standard factory connection point. Both SW headers and SW exhaust are used in this configuration. We've developed a system which maintains a full 3" diameter and X-pipe which creates the ultimate horsepower experience. Check it out here: 2016 Camaro SS Stainless Works Headers |
05-17-2017, 05:56 PM | #2 |
Drives: 2017 ZL1 Join Date: Nov 2012
Hello! Could you PM prices on the SW catback and axle back for my 2017 ZL1?
Shipped to 38128
2017 Camaro ZL1
2015 GTR FBO E85 |
09-10-2019, 10:55 AM | #3 |
01-20-2022, 03:54 PM | #4 |
