04-16-2013, 05:11 PM | #57 |
Drives: 2013 Ashen Gray M6 ZL1 Join Date: Sep 2012
VegasZL1. Where you at an intersection (90 degree left or right) or in a curve and fully accelerated to allow the PTM 2 to modify the level of engine power for a smooth and consistent corner exit. (Owners Manual Pg 9-40). I've pulled out plenty of times making a left or right and punched it, the engine dies rights down even though I still have it floored, and I thought it was to stop all the wheel spin. Also tried exiting a really nice hi-way curve, punched it (WOT) but chickened out before the system modified the power. Didn't think I had the skill level and got to nervous before it started chirping in the turn. Speed I let off was 80 to 90. Too much to soon for a beginner. Didn't want to lose control of her so I backed off the acceleration.
04-16-2013, 05:29 PM | #58 | |
2015 SS 6M
High Performance 2012 - Inside The 580HP Camaro ZL1 Not really but it is a really great technical article. Here's the most pertinent info to this discussion. It talks about Launch Control specifically, rather than No Lift Shift however, we know they are related functions. The Launch Control system functions through the Electronic Brake Control Module (EBCM) and the Engine Control Module (ECM), and is fed signals from the wheel bearing-based ABS sensors. The EBCM is where the wheel speed inputs go; it has the algorithm that requests whatever torque it thinks it needs. Most of the system's brains live in the EBCM, but the ECM holds the RPM and cuts spark/fuel/throttle. In short, the ECM does the torque mitigation and figures out how to deliver the torque, and the EBCM figures out how much torque it wants and makes the request. "A good driver can beat the Launch Control by usually 1 to 2 tenths," Tony admits. "But the Launch Control is consistent all day long. It factors in a cold outside temperature and knows that the engine is making a little more torque, or knows the engine is a little warm and is making less torque, and adjusts accordingly. This system's consistency prevents an inexperienced driver from going up in smoke because of a track or weather change."
04-16-2013, 06:31 PM | #59 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Here is what I've gathered about the no lift shift feature from experience and what I've read about on other GM models.
- The NLS algorithm is controlled in BCM - Must be at or near WOT - 95% or greater TPS - Shift must occur in .50 seconds or less (clutch engaged, shift gear and clutch disengaged) - Must shift above a certain rpm 5000-5500 min rpm. I think it's 5000 rpms based on datalogging. - The rpms will jump up during the shift (how much depends how close you shift to the rev limiter) and held at redline. The quicker the shift; the less chance it will jump up. - The fuel/spark rev limiter (i.e. cut off) will not be activated at redline. - If done properly; the supercharger will stay in full boost, PE (Power Enrichment -commanded WOT AFR) will be maintained as well as full WOT spark timing throughout the shift. It would be nice to see the actual algorithm parameters; but once again this based on my own observations by driving and datalogging my own car and reading on other GM cars with this feature. |
04-16-2013, 06:53 PM | #60 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
just gave this a try from a roll and it does work awesome! so it does work from a launch or roll. not that i didnt believe everyone, just had to see for myself.
04-16-2013, 08:04 PM | #61 |
DrkPhx. Outstanding info! Good stuff to know. So from what I just read you can do this at anytime. I could be on the hi-way doing 50, downshift and punch it (WOT) and do the NLS. Or from a roll or from Launch Control. Sounds like this car is going to be a lot of fun.
04-17-2013, 01:16 AM | #62 |
Okay People, here are some more videos.
After paying more attention to what the motor sounds like when it's hitting the rev limiter versus the sound it makes during the NLS procedure, I'd have to say that (as far as the sounds its making) what silverds says makes some sort of sense. I'm not sure what the point of limiting the available torque from the motor would be while the clutch is pushed in, unless it's to prevent the all of said torque from making you fly off the road once you release it... Again, it makes sense...but it's still an educated guess at best. However, at this point it seems to be the best explanation. I tried to keep the camera as still as possible during this, but the jolts from the shifts make it a little difficult to watch the tach closely as you will all see... The first video is simply running the car up to the rev limiter in second gear so you can hear what it sounds like: The second, a launch in PTM3 with NLS. As you all probably know, PTM3 keeps active handling turned on, but for whatever reason the car was more lively than the later videos; which is why the video is somewhat crap in the beginning...I chose to keep the car on the road as opposed to going in the ditch: Third video, PTM5 & NLS: Fourth video is for those of you who were wondering about shifting at 5k. The way I sit in the car makes it difficult to see the tach, so I missed the 5k point for the first couple of shifts, but the 3-4 shift is right on the money. Done in PTM5: Last video, same as above but done at 5500: |
04-17-2013, 01:54 AM | #63 | ||||
Awesome job with the videos... Great thread Normagene... Thanks for starting it. |
04-17-2013, 06:25 AM | #64 |
great vids
04-17-2013, 06:43 AM | #65 |
hmmm, i dont hear you chirping tires through those gears. i usually chirp third when performing this action.
04-17-2013, 06:54 AM | #66 |
Drives: 2015 Camaro Z/28 Join Date: May 2011
I've been reading this great thread with interested. Dumb question time. A friend wants to know (not me of course), if NLS is active all the time, or do you have to be in a PTM mode? In the interest of full disclosure, I'm, I mean my friend, is driving a ragtop ZL1, and is limited to touring and sport mode. He uses the no lift shift method frequently, but not sure if he's getting the benefit of the NLS feature. He also sometimes turns off traction control, because he loves to see fear in the eyes of hapless Mustangs, and old ladies jump off the sidewalk when they hear the scream of his Conti Extreme Contacts. But I digress....
So is it always there? Geno
Now: 2015 Z/28
Former: 2013 ZL1 Vert Crystal Red 1978 Corvette Pace Car 1969 Pace Car 1969 Z/28 Cortez Silver, 1974 LT/Z28 Blue 1974 Z28 Dark Green , 1976 Camaro Type LT Black 1980 Z28 Charcoal, 1981 Z28 Dark Blue 1981 Z28 Claret, 1982 Pace Car 1986 IROC Red, 1993 Z28 Red 1996 Z28 vert, 1998 Z28 Dk Blue 2002 B4C 2004 Vette LeMans Blue 2008 Vette - CRT 2011 Camaro Pace Car |
04-17-2013, 11:27 AM | #67 |
Geno. NO LIFT SHIFTING IS ACTIVE AT ALL TIMES. Launch Control is active when: In "Competitive Driving Mode" or for the ZL1's "In a PTM".
VegasZL1. OUTSTANDING VIDEOs! A pictures worth a thousand words. Great job. I've watched each one a half dozen times. Definitely going to give this a try - and real soon! During the Launch, it didn't seem/sound like there was ANY tire spin. I can hear the engine holding down the torque it seems. When I used Launch in my SS there was way to much tire spin. Seems like the ZL1 is dialed in way better for grip and fastest launch possible. Thank you so much for these videos! |
04-17-2013, 11:35 AM | #68 | |
2015 SS 6M
04-17-2013, 11:35 AM | #69 | |
Geno
Now: 2015 Z/28
04-17-2013, 11:44 AM | #70 | |
