07-05-2022, 04:06 PM | #1 |
Drives: 2018 SS 1LE Join Date: Sep 2018
oil level / top off
i only put about 1,700 miles since my last change.. but the oil level was at 2%
so i decided to top it off with 4 quarts in the meantime BUT the oil level didn't change at all.. noob here.. something i'm doing wrong?
2018 SS 1LE
07-05-2022, 04:13 PM | #2 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Do you mean the oil life monitor was at 2%? If so, that has nothing to do with the oil level. Did you check the oil level before and after adding oil?
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
07-05-2022, 04:15 PM | #3 | |
i checked before and after but it didn't change
2018 SS 1LE
07-05-2022, 04:18 PM | #4 |
The oil life monitor won’t change until you reset it. You don’t reset it until you change the oil. It has nothing to do with oil level. Don’t drive your car until you check the oil level…….it’s probably way over full if you added 4 quarts without draining any.
07-05-2022, 04:23 PM | #5 |
thanks.. i didn't realize you could reset it manually.. i'm dumb
2018 SS 1LE
07-05-2022, 04:24 PM | #6 |
Drives: blue velvet Join Date: Jul 2018
the oil life monitor is based on usage + time. i'm guessing you're coming up on a year, which means you should change it anyways.
07-05-2022, 04:26 PM | #7 | |
So, did you drain the oil before adding the 4 quarts? If not, you have a big problem. Check the oil level on the dipstick or have someone do it if you’re not sure how to do it.
07-05-2022, 04:26 PM | #8 |
yeah a little less than a year now.. don't drive much
2018 SS 1LE
07-05-2022, 04:28 PM | #9 | |
2020 Shadow Gray 2SS
As others have said, you are VERY likely WAAAY over full on your oil now, do NOT start your engine until you get the oil level proper.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
07-05-2022, 04:28 PM | #10 | |
ah man.. i may as well just do it the right way now
2018 SS 1LE
07-05-2022, 04:30 PM | #11 |
It can’t be fine. No way was it 4 quarts low before you added the oil. It’s probably 2”-3” above the full mark on the dip stick. Don’t start your car!
07-05-2022, 07:47 PM | #12 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
This is the craziest post I've ever read here. Either your oil was incredibly low before or it's about to overflow now.
I would suggest taking your car to a shop to do this for you. |
07-05-2022, 07:58 PM | #13 |
Drives: Where to begin... Join Date: Mar 2017
So...just curious. How does one land on 4 quarts here?
07-05-2022, 08:53 PM | #14 | |
hopefully i didn't do any damage driving there
2018 SS 1LE
