09-15-2022, 05:12 PM | #29 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
09-15-2022, 06:49 PM | #30 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Yes, you can change out the dust boots without pulling the pistons. Just be gentle around the pistons.
09-16-2022, 06:26 AM | #31 |
Drives: 1LEs Join Date: May 2009
Sorry, I missed the question. The pistons only need to come out to change them and / or the pressure seals. The dust seals you can just take a dental pic or something like that to help pull the seal out of the bore and off the piston upper lip. You can then press new ones back on with your fingers. It's easiest to do with the caliper off the car, but, you can do it with the caliper either still bolted to the knuckle or unbolted from the knuckle but still attached to the brake (fluid) line.
09-16-2022, 01:11 PM | #32 | |
Drives: 2018 SS 1LE Join Date: Oct 2017
11-19-2022, 11:11 AM | #33 |
Drives: 2017 HBM Camaro SS 1LE Camaro Join Date: May 2013
Hoping to get some clarity on which vented piston and seal kit to purchase for front calipers. I have a 2017 SS 1LE with the stock calipers. Do I purchase the 19207043 kit or the 23242510 kit?
Also, anyone have an idea of where to source the 19207044 front caliper dust boots? Seems like everywhere is stocked out. Appreciate the help. |
11-20-2022, 05:04 AM | #34 | |
For the SS 1LE: Part No. 23242510 x2 (vented pistons + seal) Part No. 19207044 x2 (dust boots) check with these guys (there are many more online) https://www.gmpartsgiant.com/parts/g...-19207044.html
11-20-2022, 10:59 AM | #35 | |
Appreciate the help! |
02-10-2023, 03:18 PM | #36 |
Driver for Hire
Apparently, I missed this thread when posting about Amazon having these kits relatively cheap. I took pictures comparing the two sets here:
Vented Kits on Amazon
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
02-21-2024, 08:31 PM | #37 |
Drives: 2018 1SS 1LE - Garnet Red Join Date: Oct 2018
I’m in the middle of this vented piston, upgrade and find it incredibly frustrating how poorly the parts are packaged. I ordered five sets to down select two and even with those odds I have to use some compromised parts with little nicks in them. If anyone has a suggestion on how to source these pistons without a bunch of scratches I’d really appreciate it.
