07-25-2020, 12:44 PM | #1 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Rear camber issue 2020 SS 1LE
Wondering is anyone has run into this issue and/or any suggestions as to what could be causing my problem:
F camber at 2.8 zero issues! Albeit i may have it dialed back a wee bit. RR 1.6 and 0.05 toe in zero issue. LR had a BIG ISSUE. If they dial 1.6 camber then they cant bring the toe back in! At that camber the best toe setting ends up at MINUS (OUT!!!) 0.3 which obviously is a huge problem. To get a 0.05 toe in the best camber they could get was 1.1... Been to 2 shops now. Last dealer suggested it may have to require part swaps done under warranty. My mechanic says it could be a cradle which is out of position, but he hasnt looked at it yet. Feedback? Comments? Similar experiences? Thank you! |
07-25-2020, 02:10 PM | #2 | |
My car was worse than yours btw, because on the front end, all we got was -2.10º and -2.06º of camber. Production variance seemed to have bitten us in the butt with this car. |
07-25-2020, 02:12 PM | #3 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Something is wrong all around.
I haven't heard of anyone being able to get -2.8 out of the front on the SS 1LE without camber plates. I could only manage -2.4 on one side and -2.5 on the other and then it was tough to keep the toe within spec. In the rear, there should be PLENTY of adjustment to go much more negative camber and still keep the toe in spec.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
07-25-2020, 02:34 PM | #4 |
Thanks guys! Yep something is odd.
I did get 2.6F on my 17 with no issues btw. On my 2020 they got 2.9 and 2.8 with no issues! What i dont get is that it is just the RL that has an issue. Clearly i cannot even consider tracking her like this. Not even being able to achieve what GM states as the track spec in the manual... If this doesn't end on a positive note, the car will be going back to GM... Apreciate any more comments/ideas as to a possible cause. Thanks! |
07-26-2020, 10:09 AM | #5 |
Drives: 20 SS 1LE Join Date: Jun 2020
What is everyone doing for the rear bolts? The camber and toe bolts are both torque to yield and should only be used once. Are you guys just retorquing them or replacing them each time? What's the torque level you are using if reusing the bolts?
John Hale
multi time solo nats runner up :( |
07-26-2020, 01:15 PM | #6 |
I am reusing the bolts. I do not track, but I have not had an issue at all with the rear holding its alignment settings.
Current:
07-26-2020, 11:02 PM | #7 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
07-27-2020, 07:26 AM | #8 | |
I think they will try replacing the toe link and maybe the control arm? Exoecting a call this am. Interestingly, i have found a post here from 2 yrs ago with a poster indicating they could only get 0.9 camber on LR, which looks exactly like my issue. Unfortunately it went stale with no conclusions. |
07-27-2020, 08:48 AM | #9 | |
Matt Miller
2020 SS 1LE |
07-27-2020, 09:31 AM | #10 | |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
mine is at 2.8.... bone stock. I had a similar issue on my old 2017... look at the rear subframe! Make sure the tabs that the bolts slide up to arent bent! Mine were and i could not get the numbers dialed in.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
07-27-2020, 10:46 AM | #11 |
Thanks! Did you get it fixed on your 17? Can it be fixed?
07-27-2020, 10:48 AM | #12 | |
Not mech inclined here, so simply dont know what this would entail...Cheers! |
07-27-2020, 11:04 AM | #13 |
"eccentrics are the devil" according to the owner/developer of SPL parts. Consider some of the parts there which appear top notch. https://www.splparts.com/
07-27-2020, 12:08 PM | #14 |
we did our best to bend them back and it worked but it was never the same. Tried to get a dealer to warranty the sub frame but wouldn't.
#53 F Street
